Author Topic: New Flywheel And Clutch Being Replaced Today. Anything else?????  (Read 3277 times)
Offline Shizzle
I am getting my lightened flywheel and new clutch fitted this afternoon is there anything i should be thinking about replacing while all this is apart i have a crank seal to fit also just want to make sure i do everything while gearbox is out and its all off.
Thanks In Advance
MK3 Golf GTI 2.0 16v 3Door Storm Grey
Offline Len
nothing else can be done.
I assume a new thrust bearing came with the clutch?
www.sas.org.uk
www.the-ace.org.uk
Offline Shizzle
Yeh and i have all new bolts for both flywheel and clutch.
Just want to make sure i don't miss anything as auto data said 4 hour job :s.
Offline Len
Well I would love to see someone do it in 4 hours!!!
www.sas.org.uk
www.the-ace.org.uk
Offline Shizzle
what you think longer got 1 of my best technicians on it we are using a ramp  :shocked:
Offline Len
Yes a lot longer!
But if you are in a professional place with a ramp and air tools it may just be possible!
www.sas.org.uk
www.the-ace.org.uk
Offline gazareth
you should check the input shaft oil seal for seepage while box is out. its the only oil seal you cant change with the gearbox in place.
Offline leigh_harty
  • Audi AGU
Change the g,box oil? :smiley:
Dont lose your dinosaur!
Offline Shizzle
Every thing above changed car drives perfect have not noticed a great power gain but engine is so smooth now  :smug:
Offline leigh_harty
  • Audi AGU
It won't change power but change the way it's delivered. Mine made a noticeable difference whilst bedding in new clutch against a mates vr  :whistle: Best thing I did to my valver  :smiley:
