Author Topic: Abf with cda vs ctn gearbox  (Read 5176 times)
Offline bigberty101
« on: 05 March 2014, 17:09 »
Got a mk3 abf with a cda gearbox, the cda is standard 16v gearbox which is basically shot, the diff is going to explode any day I recon.
What I need to know is the cda is so revvy, it goes well and that but I do a lot of motorway miles and just after something not so revvy, doing 3-4000 ramp and 70ish mph is killing me on fuel, just wondered if anyone has fitted a ctn diesel gearbox off a 1z mk3 on a abf and what were the results, or any suggestions as to what to use if not? Not really wanting to but swapping internals to get the gearbox how I want it, would prefer something I could just "bolt on" and get it to work?
Any help would be greatly appreciated and I have done many hours of research and not been able to fine a definitive answer
Offline Len
Re: Abf with cda vs ctn gearbox
« Reply #1 on: 05 March 2014, 20:43 »
4000 revs in mine is 90mph, so something not right!
www.sas.org.uk
www.the-ace.org.uk
Offline bigberty101
« Reply #2 on: 06 March 2014, 08:53 »
the flywheel has been lightened, the cranks has been polished, knife edged and balanced, the bores have been honed and slightly oversized, the head has been gasflowed, polished and ported with uprated valve train, and every since this engine has been in, its always been around that figure,
is your gearbox code deffo cda?
Offline Foreveryoungaus16v
« Reply #3 on: 06 March 2014, 10:11 »
Thought you from Taunton my friend?
« Last Edit: 06 March 2014, 10:12 by Foreveryoungaus16v »
163 BHP (TSR POWER RUN)
Offline spikenipple
« Reply #4 on: 06 March 2014, 10:19 »
Sounds like you might have a different final drive fitted to that gearbox perhaps?
Offline Len
« Reply #5 on: 06 March 2014, 12:24 »
Mines an 02 gearbox
www.sas.org.uk
www.the-ace.org.uk
Offline bigberty101
« Reply #6 on: 06 March 2014, 12:36 »
gearbox is completely standard, come out of a mates parents car which failed mot on rot, they were the original owners and had nothing done the engine / gearbox until I got it.
im from kesgrave in Ipswich
Offline bigberty101
« Reply #7 on: 06 March 2014, 12:37 »
and len, is it an 02a gearbox? I would assume with hydro clutch and cable shift. just trying to find a suitable ratio box to fit on that's not so revvy, its killing me on fuel, and imafter a few longer ratios, hint why Im after a ctn box, a mate has one in his abf but is unsure on code, its off a diesel audi a3
« Last Edit: 06 March 2014, 12:39 by bigberty101 »
« Reply #8 on: 06 March 2014, 13:16 »
Speak to the Abf master
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #9 on: 06 March 2014, 14:04 »
Glen?
