Author Topic: Heres my job for this weekend !  (Read 1972 times)
Offline northeast_gti-t
  • "1.8T AGU"
« on: 04 March 2014, 21:25 »
Well bought my golf knowing there was some clutch slip  :laugh: but already has the G6o flywheel and vr6 clutch conversion well after two weeks of ownership i have decided its time to bite the bullet and sort it was going to be lazy and get the clutch kit and let a local garage fit it but they are wanting to much money so i will be fitting it in my garage saves labour rates!  :grin: ordered this one: http://www.eurocarparts.com/ecp/c/Volkswagen_Golf_2.8_1996/p/car-parts/car-transmission/clutch-and-associated-parts/clutch-kit/?641440660&1&bc37de266ef97df2f579c1787084f49d9832f815&000069
Can't wait to get this done now so i can have a decent clutch and hopefully find the fault of the existing clutch i know what company fitted it and looks like a bad job  :undecided:
2000 Mkiv GTi 1.8T AGU
Offline GTi_James
Re: Heres my job for this weekend !
« Reply #1 on: 05 March 2014, 08:11 »
Is that the full kit to replace the standard?  :shocked:
Offline joshstanvw
« Reply #2 on: 05 March 2014, 10:12 »
You will probably find the ring that holds the springs in the clutch has disintegrated lol mine did you could turn the clutch whilst keeping the splined part in a vice good luck with the swap it's not that bad to be fair took me about 6 hours overall on the driveway in the rain
GTI is not a trim level. It is a lifestyle.
1999 1.8t AGU, KO3s, forge 007p, silicone tip and charge pipe, oil catch can, SS turbo back system, pipercross CAI, g60/vr6 clutch, 40mm apex springs, drilled and grooved discs, stage 2 remap.
  • "1.8T AGU"
« Reply #3 on: 05 March 2014, 22:02 »
yes three piece kit for a vr6 as its the conversion funnily enough the oem mk4 clutch is more expensive  :laugh:
  • "1.8T AGU"
« Reply #4 on: 05 March 2014, 22:05 »
will keep a look out for that then bud once i get the box off,hopefully the new one sorts my issue,yes doesn't look to bad a job and cheers i'll be in  a garage at least  :smiley:
Offline joshstanvw
« Reply #5 on: 07 March 2014, 20:54 »
This guide should help I used it for those "how the **** does that come out moments
http://myfastgti.com/volkswagen/threads/12367-2004-Mk4-1.8T-Jetta-GLI-GTI-Clutch-Replacement
The biggest help was when it's all unbolted rotate the gearbox diff side up and pull it off luckily I have a brute of a cousin that did that for me
  • "1.8T AGU"
« Reply #6 on: 08 March 2014, 22:58 »
:afro: cheers found the very same link in the maintainance section,gearbox and clutch now sat on the garage floor  :grin:
  • "1.8T AGU"
« Reply #7 on: 08 March 2014, 23:07 »
Got the gearbox out earlier after fighting it out from the car,rear crank and input shaft seals all dry so good start,friction plate and release bearing are f$$$$d coverplate seen better days to and scored up so all that lots been binned  :grin: clean up and will get it re-assembled tomorrow
