Author Topic: new boost pipes help needed  (Read 2923 times)
Offline wsmith
« on: 04 March 2014, 20:58 »
ive fitted new boost pipes on my 1.8t which is remapped  but since fitting them i can hear more turbo noise louder than normal on full boost  ,it still peaks the same on the boost gauge but i noticed on fitting them there is a pipe just up from the pancake is there a upgraded part for that as i think the noise is coming from there ??
Offline daz veedub
  • Operation 1.8t bolf
Re: new boost pipes help needed
« Reply #1 on: 04 March 2014, 22:41 »
You mean the pipe coming of the inter cooler to throttle bodie
Offline wsmith
« Reply #2 on: 05 March 2014, 08:18 »
No the other side of the pancake to the metal pipe
Offline sharki786
  • GOT BOOST??
« Reply #3 on: 05 March 2014, 11:03 »
think his on about the n75 hoses. If it is then yes you can buy silicone hose for that from creation motor sport.
Hopefully this is what your on about http://creationsmotorsport.com/product-detail.php?pid=412
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline daz veedub
« Reply #4 on: 05 March 2014, 11:35 »
N75 pipe isnt near the pancake pipe tho lol but yeah them kits from creation are good
Offline sharki786
  • GOT BOOST??
« Reply #5 on: 05 March 2014, 13:30 »
Your right 1 pipe goes from the dv to a metal pipe behind the engine. Get a pic up of it.
*****MK4 GTI T*****
Offline wsmith
« Reply #6 on: 05 March 2014, 14:13 »
Its the pipe just off the pancake to the metal pipe you can see it from under tne car , ive upgraded all them pipes
Offline brewey
« Reply #7 on: 05 March 2014, 19:10 »
The pipe between pancake pipe and intercooler comes in most kits. I know the 5 piece creation motorsportd on do. Alternatively just get done correct diameter silicone hose and cut it down to size, after all it's only about 5cm long anyways.
2000 1.8T ARZ - OEM+
Offline james2
  • No scammers please.
« Reply #8 on: 05 March 2014, 19:30 »
They do not do a upgrade pipe unfortantly. Best bet is to buy a new one from vw.
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline wsmith
« Reply #9 on: 05 March 2014, 19:49 »
cheers
