Author Topic: new boost pipes help needed  (Read 2930 times)
Offline brewey
Re: new boost pipes help needed
« Reply #10 on: 05 March 2014, 20:11 »
http://creationsmotorsport.com/product-detail.php?pid=56
As said in my other post creation MS do one. You can see it clearly in the picture. It even states pancake to IC.
2000 1.8T ARZ - OEM+
Offline wsmith
« Reply #11 on: 06 March 2014, 05:39 »
I've replaced all them it's the other side of the pancake I need
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
« Reply #12 on: 07 March 2014, 09:14 »
ive fitted new boost pipes on my 1.8t which is remapped  but since fitting them i can hear more turbo noise louder than normal on full boost  ,it still peaks the same on the boost gauge but i noticed on fitting them there is a pipe just up from the pancake is there a upgraded part for that as i think the noise is coming from there ??
I think this is the one you need
I have one that I could probably sell you  :smiley:
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
Offline wsmith
« Reply #13 on: 07 March 2014, 20:07 »
it that the one thats off the pancake to the metal pipe ( otherside of the intercooler pipe ) if yes how much and is it blue  cheers
Offline sharki786
  • GOT BOOST??
« Reply #14 on: 07 March 2014, 21:19 »
Why dont you get a pic of it up? As im lost now :laugh:
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline wsmith
« Reply #15 on: 07 March 2014, 21:40 »
Follow from the intercooler to the little silicone pipe than pancake than the pipe I need - it connects the pancake to the hard pipe
« Reply #16 on: 08 March 2014, 07:57 »
If you mean the one that connects to the charge pipe that is round the back of the engine and eventually connects to the turbo with a sort of upside down L pipe, then yes it is.
What engine have you got? is it an AUM or AGU? I ask because if it is the AUM, you will need to change the charge pipe to an AGU one to fit this pipe, which I also have spare.  Yes it is blue!
« Last Edit: 08 March 2014, 08:05 by oceanic-green »
