Author Topic: Single mass flywheel or dual mass flywheel?  (Read 5076 times)
Offline shaunmorton
« on: 28 February 2014, 21:38 »
Hi guys. Just a quick one. The clutch is coming up for replacement and I was wondering if it's worth going with the cheaper option and getting a smf? What will the difference be?
2001 mk4 gti aum 1.8t
Longlife custom built non res cat back & k&n oem replacement
Offline Rhyso
Re: Single mass flywheel or dual mass flywheel?
« Reply #1 on: 28 February 2014, 22:14 »
If its a GTI go single
Diesel stick with dual mass
Offline shaunmorton
« Reply #2 on: 28 February 2014, 22:54 »
Yeh it's a aum 1.8t. Will I notice any difference or not with the single mass? I don't mind spending a little extra on the dmf if it's going to make it drive nicer
Offline mcgee9t2
« Reply #3 on: 01 March 2014, 09:57 »
Should feel a little more responsive.
Offline navmk4gti
« Reply #4 on: 01 March 2014, 12:18 »
Go for the g60 flywheel and vr6 clutch if yours is 5 speed :wink:
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #5 on: 01 March 2014, 21:33 »
:afro: mines already had both fitted and the pedal is nice and light and more responsive imo than the oem dual mass fitment  :cool:
2000 Mkiv GTi 1.8T AGU
Offline davemk4
« Reply #6 on: 02 March 2014, 07:56 »
ive got the g60/vr6 combo on my aum miles better than oem
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline shaunmorton
« Reply #7 on: 03 March 2014, 10:02 »
Cheers for the help! I may go with the g60/vr6 conversion then! Is that gonna be a straight swap for the oem parts or does anything need to be modified? And how much do you think it will cost me for the bits?
Offline navmk4gti
« Reply #8 on: 03 March 2014, 11:07 »
Straight fit and cost me about 150 for the clutch and flywheel and then 120ish for fitting. That was about 3 years back  :grin:
Offline shaunmorton
« Reply #9 on: 03 March 2014, 11:39 »
Nice one. I thought I'd have a look at other post about it and found a kit on eBay for 199 and that's SACHS branded as well so I'll go with that I think. I like to hear nothing but good feedback about this conversion as well!
