Author Topic: vinyl wrap interior help  (Read 1246 times)
Offline scottv6
« on: 26 February 2014, 19:58 »
going to be wrapping the trim on my mk4 took the handles off but does the insert bit that im wanting to wrap come out?
Offline joshstanvw
Re: vinyl wrap interior help
« Reply #1 on: 28 February 2014, 12:36 »
They appear to be glued on you could most likely pry them off carefully but they would need gluing back
GTI is not a trim level. It is a lifestyle.
1999 1.8t AGU, KO3s, forge 007p, silicone tip and charge pipe, oil catch can, SS turbo back system, pipercross CAI, g60/vr6 clutch, 40mm apex springs, drilled and grooved discs, stage 2 remap.
Offline dom
  • Back in a Mk4
« Reply #2 on: 28 February 2014, 13:20 »
They will break if you try to remove them, when I did mine I placed the vinyl over the whole handle and carefully cut around the insert with a sharp craft knife.
Offline scottv6
« Reply #3 on: 28 February 2014, 20:33 »
that's what I ended up doin dom, got the handles done now doing the rest of it at the weekend.
