Author Topic: Rear beam centring plates  (Read 4236 times)
Offline bigberty101
« on: 24 February 2014, 22:56 »
Evening guys,
As the title sates, has anyone used any rear beam centring plates? I've done many hours of searching and can't find any for mk3, found plenty for mk4.
I'm not after ones which don't bolt to the beam and lift the hub, I don't personally trust them after a mates incident. I've always preferred the type which you unbolt the mounting bracket from the chassis and bolt on, then bolt the beam to them. That's what you do on the mk4, just wondering if you can do it on mk3, never really closely inspected the beam mounting point so I'm not sure if it's detachable like a mk4.
Here's an example of what I mean http://www.psituning.com/product.php/21116/ecs_wheel_centering_plates_mk4_tt_mk1
Joe
Offline gasketface
Re: Rear beam centring plates
« Reply #1 on: 24 February 2014, 23:14 »
On a MK3 the brackets that bolt to the chassis that the beam mount to are removable.If i remember rightly they have 3 bolts holding each one to the chassis.
I may be talking out of my **** but can you not just elongate the holes on each bracket
 to achieve what you are trying to achieve .
« Reply #2 on: 25 February 2014, 00:00 »
Taking or removing metal from them is not really a good idea, they need a lot of strength around the mounting holes.
Offline gasketface
« Reply #3 on: 25 February 2014, 00:11 »
Weld up the original holes and drill new one's ?
Offline bigberty101
« Reply #4 on: 25 February 2014, 08:56 »
thought of that but would rather pass on the idea, as mentioned, not really an idea solution
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #5 on: 25 February 2014, 09:37 »
mk3 plates are available as a guy was making and selling them on one of the facebook groups as it happens as i was questioning him about them.
Il see if i can dig some info up if i get the chance...
« Reply #6 on: 25 February 2014, 09:47 »
This isn't the guy I was talking about but I know this company in the states were quite popular for this kind of stuff a while ago.
http://forums.vwvortex.com/showthread.php?4367606-gt-BRAND-NEW-From-MASON-Tech-GREAT-PLATES!!
Im not sure if they're still operating as their website is down and has been for some time by the looks of things.
Offline bigberty101
« Reply #7 on: 25 February 2014, 10:00 »
yea there the ones i'm after and sin that on vortex before, shame there not still hade because I would have a set for sure! shame thou
Offline bigberty101
« Reply #8 on: 25 February 2014, 10:07 »
whoop whoop, I've found some at last and ball joint extenders and track rod flip kit, been after these bits for a while! quite expensive but at least they will be worth it.
http://ourtech.bigcartel.com/category/mk3-golf
Offline bigberty101
« Reply #9 on: 25 February 2014, 10:08 »
damit, wrong ones, there for the hub
