Author Topic: is it ok to have boost gauge and bora vents both running off dimmer switch power  (Read 1007 times)
Offline Carl!
just before I attempt to finish bora vents off (only taken me all day) is this ok?! if not how do I work round it!
« Last Edit: 16 February 2014, 08:41 by Carl! »
Offline Nino
Yes I run mine like this.
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline Carl!
Second question, how have you done it?
The boost gauge is currently wired in with a scotch lock although I have read that these aren't ideal.
Offline Rhyso
Mine was scotched lock and i had no problems
Just make sure the connection is nice and tight
Offline GTi_James
get some splicers from ebay, easiest neatest way of doing it imho and as Nino says its fine with the dimmer
