Author Topic: Abf inlet sensor  (Read 3912 times)
Offline bigberty101
Abf inlet sensor
« on: 14 February 2014, 19:30 »
Really struggling to find out what the sensor is on the abf Inlet inbetween cylinder 2&3. The abf is out if a seat Ibiza with aircon, trying to find one off a vw so it says vw instead, but all around the local scrappys to me don't have this sensor, anyone have any idea?
Didn't know weather it's a switch for air con some how? Or wether it's inlet pressure ( dout it thou) or inlet temp but you have a temp sensor or the intake pipe near the airbox. Any ideas?
Offline itavaltalainen
Re: Abf inlet sensor
« Reply #1 on: 14 February 2014, 19:40 »
photo?
if it's a round sensor that has a bolt going through it that holds it against the block then i'd guess it's the knock sensor.
what's the issue with it?
Offline bigberty101
« Reply #2 on: 14 February 2014, 19:56 »
No that's on the block ain't it, this is on the inlet manifold, I can't post a pic on my phone I don't think. It's a brass coloured round sensor with a single wire going to it, and I want to swap it from seat inlet to vw inlet, abf engine is out if an Ibiza and in my mk3.
« Reply #3 on: 14 February 2014, 20:17 »
inlet air temp
Offline Screech16v
  • MK3 20vt AGU
« Reply #4 on: 14 February 2014, 22:13 »
It's the engine bay temp sensor to tell the fans to come on, say you've been on a run on a hot day you've just switched off and left the vehicle parked,engine bay temps will start to rise and this sensor will kick the fans in,not all abfs have this.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #5 on: 14 February 2014, 22:39 »
Bingo, I knew it was temperature related Joe. :rolleyes:
Offline Ess_Three
« Reply #6 on: 15 February 2014, 10:22 »
It was fitted with Air con as far as I know.
Mine has it (and Air Con) and none of my mates' 16vs have had it fitted (all without Air Con)
..but gaining motorcycles.
Offline madmanmart
« Reply #7 on: 15 February 2014, 10:32 »
Yeh mines got it too and the fans are always on when parked up.
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
« Reply #8 on: 15 February 2014, 10:56 »
Snap. My neighbours knocked on the door a couple of times wondering why it was making funny noises. Ha :grin:
Offline Screech16v
  • MK3 20vt AGU
« Reply #9 on: 15 February 2014, 11:05 »
Yep mine used to have air con and an abf infact :grin:
