Author Topic: Problem number 2  (Read 1764 times)
Offline Mdwalshy
Problem number 2
« on: 13 February 2014, 08:21 »
Well my rough idle has been sorted now after weeks of hunting for it, it came down to 2 air leaks. One leak on the pipe from the brake servo to the inlet and the other on a breather pipe right beneath the inlet so thanks for all the help :-)
Anyway problem 2 is the coolant temp sensor. When I drive, the temp gauge drops and when stood still it's rises to the correct temp of 90 until I set of again and then it drops. Got it code read and came up with coolant temp Sensor so I changed this. The problem is still there and was code read again and is coming up with coolant temp sensor implausible signal?? Anyone have any ideas? Maybe a faulty new temp sensor?
Thanks
Mike.
Offline sharki786
  • GOT BOOST??
Re: Problem number 2
« Reply #1 on: 13 February 2014, 09:35 »
Sound like the thermostat needs replacing. I would replace that
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline WadGTI
  • Golf GTI'er
« Reply #2 on: 13 February 2014, 12:13 »
yeah sounds like thermostat. best to change both if you can.
Offline Nino
« Reply #3 on: 13 February 2014, 12:31 »
It will be the thermostat as you have already changed the twmp sensor. Just ensure you use oem parts and not cheap crap
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline WadGTI
  • Golf GTI'er
« Reply #4 on: 13 February 2014, 12:37 »
Opps...just noticed he said he already changed the temp sendor  :grin:
Offline Mdwalshy
« Reply #5 on: 13 February 2014, 12:58 »
Cheers for the advice will get a thermostat on order now :-)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 13 February 2014, 15:09 »
Did you use a genuine temp sender?
Offline Mdwalshy
« Reply #7 on: 13 February 2014, 15:19 »
I'm not sure but I doubt it as it was a local garage who ordered the part and fitted it, so guess it was from there parts supplier.
Offline Scott D
« Reply #8 on: 13 February 2014, 16:55 »
I have a spare brand new genuine sensor if your after one?
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline dom
  • Back in a Mk4
« Reply #9 on: 13 February 2014, 17:10 »
A cheap sensor could well be the problem, they are notorious for failing prematurely
