Author Topic: correct radiator fan operation?  (Read 1138 times)
Offline bikeman
« on: 12 February 2014, 13:31 »
Hi
I'm concerned that my radiator fans aren't operating correctly on my mkiv 1.8T climatronic. At 90 degrees in Econ mode (ie aircon off) they still aren't on.
Would someone with a 1.8T climatronic tell me at what temp their fans start in econ mode.
Thanks
Offline damien010685
Re: correct radiator fan operation?
« Reply #1 on: 12 February 2014, 14:03 »
You aware they are not on permanent?? If you sit idling for 5 mins do they come on?
Offline EsSeX dAn
« Reply #2 on: 12 February 2014, 19:24 »
thus is normal. they only come on oermanently when air con is turned on
i think i love you.....
Offline bikeman
« Reply #3 on: 15 February 2014, 09:32 »
Hi Thanks for the replies but my question was 'at what temp should the fans come on in econ mode'?
At 90 degrees mine still haven't started and I don't want to over heat it just to test this.
Thanks.
« Reply #4 on: 15 February 2014, 10:09 »
90 degrees is the temperature it should be at not sure of the exact temp as long as it's not going above 100 then there should be no issue! Mine sits at 90 always and I only hear the fans if I sit idling for 5 mins
