Author Topic: Alternator charge fluctuating  (Read 1218 times)
Offline MaXXeH
  • Golf MK5 GTI
« on: 09 February 2014, 06:55 »
I have a problem with a AGU not charging correctly and the battery keeps going flat.
using a multimeter with the car running the V goes to 11.9v - 14v  11.9v back and forth.  You can hear the change in the engine note.
any ideas?  not sure it is a short or alternator is dead.
Offline sharki786
  • GOT BOOST??
Re: Alternator charge fluctuating
« Reply #1 on: 09 February 2014, 07:25 »
Sounds like the alternator has had it. Other way of checking it would be start the car and disconnect the battery while engine is running. I know with older cars you can do that but not sure with a mk4.
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 09 February 2014, 18:23 »
Funnily enough I have a 120amp alternator for sale lol
Offline itavaltalainen
« Reply #3 on: 09 February 2014, 20:09 »
or just replace the shot voltage regulator on it for 10£
