Author Topic: Fault code P2187  (Read 6784 times)
Offline russs99
Fault code P2187
« on: 06 February 2014, 19:38 »
Hi
My GTI started playing up last night. I noticed when in neutral the revs weren't dropping down to the usual idle level straight away. Also if I blip the throttle the revs stay at about 1300rpm then slowly drop away over about 5 seconds, then climb again etc etc. It sounds slightly rough too but not terrible. No noticeable performance problems and hasn't triggered any warning lights on the dash (yet).
I did a scan and got the below. Any ideas?
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115 Q    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0020
   Revision: 5BH16---
   Coding: 040300031C070060
   Shop #: WSC 01279 785 00200
   VCID: 346D049057C5AEBE40B-8061
2 Faults Found:
008583 - Bank 1; System too Lean at Idle
               P2187 - 004 -
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 104078 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:16:54
             Freeze Frame:
                    RPM: 1151 /min
                    Load: 26.3 %
                    Speed: 2.0 km/h
                    Temperature: 83.0°C
                    Temperature: 21.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 14.097 V
001287 - Idle Control System RPM
               P0507 - 001 - Higher than Expected. - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 104078 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:16:59
             Freeze Frame:
                    RPM: 1065 /min
                    Load: 14.9 %
                    Speed: 0.0 km/h
                    Temperature: 84.0°C
                    Temperature: 23.0°C
                    Voltage: 14.224 V
Readiness: 0000 0000
Thanks
Russ
Offline russs99
Re: Fault code P2187
« Reply #1 on: 06 February 2014, 21:34 »
I've just noticed there's a hissing noise which is audible after engine is switched off. Goes on for about 10 seconds. Had engine cover off (which was a battle) and cannot see any split pipes...
Offline Rhyso
« Reply #2 on: 06 February 2014, 22:31 »
PCV valve??  :undecided:
Offline russs99
« Reply #3 on: 06 February 2014, 22:53 »
I think you are right, I've come to same conclusion after a bit of googling. Hissing was definitely coming from immediately under engine cover. Will try and get one tomorrow but I doubt it'll be a stock part so may not be able to sort straight away.
Offline Rhyso
« Reply #4 on: 06 February 2014, 22:58 »
Order it early enough and you should get it for Saturday morning
I reckon its a stock item though.........
Offline th3_f15t
« Reply #5 on: 06 February 2014, 23:02 »
Run the test on the PCV. Run you engine and remove the oil cap for a second. If the end one tries to stall its all good. If it carries on running fine, not so good.
Moving over to Flickr, sorry for the broken picture links!
Offline russs99
« Reply #6 on: 07 February 2014, 16:06 »
Managed to get hold of a PCV valve today and successfully changed it, took about 15 minutes. Cleared fault codes and went for a spin - fault cleared and massive difference, the car must have been running really badly before. The valve unit is the 'N' variant (06F 129 101N) and cost £38 incl VAT, the one I took off was F variant. Anyway I am happy to have been able to sort it quite cheaply. Thanks for guidance!
Russ
Offline Rhyso
« Reply #7 on: 07 February 2014, 16:25 »
Good stuff  :cool:
Offline chrisvectra
  • Vectra Vxr built not bought
« Reply #8 on: 11 April 2014, 10:23 »
did you take pictures?
Offline boneybradley
  • Back in a Mk3...
« Reply #9 on: 11 April 2014, 15:38 »
That's a good price too. Was it genuine?
