Author Topic: Wheel Bolts  (Read 1384 times)
Offline GTi_James
Wheel Bolts
« on: 05 February 2014, 18:54 »
So, finally got me some wheels however i am preempting the wheel rub on the fronts and have got me some 5mm spacers however i need to know the best bolts to use with them. never really given it much thought but now i hear tell there are certain ones to steer clear from. any help would be appreciated fellas
Offline james2
  • No scammers please.
Re: Wheel Bolts
« Reply #1 on: 05 February 2014, 19:07 »
you need ones that are 5mm longer. I got mine off ebay and they came with the bolts.
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline GTi_James
Re: Wheel Bolts
« Reply #2 on: 05 February 2014, 19:29 »
but arent there differences in different type of bolts, i.e. some are stronger than others etc
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Wheel Bolts
« Reply #3 on: 05 February 2014, 19:38 »
standard length bolts are fine with 5mm spacers
Offline dom
  • Back in a Mk4
Re: Wheel Bolts
« Reply #4 on: 05 February 2014, 20:52 »
As Wazzzer says, standard bolts are fine, I ran mine for thousands of miles without issues.
Offline northeast_gti-t
  • "1.8T AGU"
Re: Wheel Bolts
« Reply #5 on: 05 February 2014, 20:58 »
And as dom and wazzzer have said before running standard bolts with 5mm spacers is fine i too ran mine with standard bolts for awhile,as for different types its mainly the seating type ie taper or ball seat
https://www.google.co.uk/url?sa=i&rct=j&q=&esrc=s&source=images&cd=&cad=rja&docid=gUHYRySBjIzwCM&tbnid=M4VVG3t8JeE5AM:&ved=0CAUQjRw&url=http%3A%2F%2Fwww.eurosportacc.com%2Fproducts%2Fh-r-wheel-bolt-12-x-1-5-select-length-and-seat&ei=h6XyUvaFF4PX0QXR9IHYCg&bvm=bv.60799247,d.ZG4&psig=AFQjCNGAwT52rWbzR8M_9UqLyI7v42ELoQ&ust=1391720157477593
2000 Mkiv GTi 1.8T AGU
Re: Wheel Bolts
« Reply #6 on: 06 February 2014, 00:11 »
What wheels have you got, should be easy enough to work out the bolts required.
Offline Nino
Re: Wheel Bolts
« Reply #7 on: 06 February 2014, 07:56 »
I got some spare bolts you can have james, i git new ones then my 3sdms came with new ones again lol
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline GTi_James
Re: Wheel Bolts
« Reply #8 on: 06 February 2014, 10:01 »
I've got two sets, rs4s 18s and the Audi convertible bbs 18s, I'll try getting some pics up
