Golf mk4
Wazzzer
possible wheel bearing?
Topic: possible wheel bearing? (Read 967 times)
Scottymk4
Here all the time
05 February 2014, 12:08 »
Hi Guys,
I am getting a grinding/creaking noise which is more noticeable when driving slow/speeding up, could this be a bearing? or brake related? whats the possible costs involved ? my car is a 1999 gti
Tezmax
GTI forum regular
Re: possible wheel bearing?
05 February 2014, 17:18 »
A wheel bearing would be more of a whistle when on its way out, if its already colapsed then yes it would be grinding.
A failing CV joint would also generate the same syptoms. Find out which corner it is, jack it up and see how much play you have on your wheel.
I would advise you not to drive it until fixed as a failing CV joint may seize up while driving.
No idea of cost
1.8t Aum. forge 007p. 17" bbs. R-tech stage 1 map.205/235. catch can.
Scottymk4
Here all the time
05 February 2014, 19:13 »
Put it into the garage who said need a few suspension parts... Drop links etc. oh and the wheel bearings on the way out
barrym381
Forum addict
05 February 2014, 19:24 »
what garage do you use
Scottymk4
Here all the time
05 February 2014, 19:50 »
Normally les weirs in milngavie but used one at my work in kinning park
Golf mk4
Wazzzer
