Golf mk4
Wazzzer
Productive afternoon
Topic: Productive afternoon (Read 1618 times)
joshstanvw
GTI forum regular
04 February 2014, 18:00 »
So I finished work early today and seeing as it was dry I decided to do some long overdue maintenance
Firstly I pulled off the 007p and gave it a good clean out as I don't think it had ever been done
Then I set about taking the throttle body off which was just pure filth so that got a good polishing through
Customised my new engine cover to fit properly just needs spraying/wrapping to look pretty
Sorted my gear shifter alignment to get first gear easily
Did an oil and filter change
And lastly moved my catch can down a bit
After all of the above the car is now so much better was pushing 11-12 psi now at 15-16 pulls so hard now so happy with it
GTI is not a trim level. It is a lifestyle.
1999 1.8t AGU, KO3s, forge 007p, silicone tip and charge pipe, oil catch can, SS turbo back system, pipercross CAI, g60/vr6 clutch, 40mm apex springs, drilled and grooved discs, stage 2 remap.
sharki786
GOT BOOST??
Re: Productive afternoon
05 February 2014, 18:05 »
An afternoon well spent then. Did you get the revised piston kit for your 007? If not then i would speak with forge. They normaly send one out in the post for free.
*****MK3 Anniversary*****
*****MK4 GTI T*****
joshstanvw
GTI forum regular
09 February 2014, 17:40 »
Cheers for the advice mate I'll ring them tomorrow
Mdwalshy
09 February 2014, 19:56 »
Bit of advice, I wanted to take the throttle body off to give it a good clean but was told if it is taken off it's need adjusting/setting with a computer ? Is that correct or just complete $&@".
Thanks
Mike.
brewey
09 February 2014, 20:42 »
It should be realigned technically. But the car relearned and aligns itself after so many miles. I've done mine a couple of times and never aligned it with vagcom.
If you've got a DBW kit don't force the butterfly valve. I you leave it plugged in turn the ignition one click and put something on the accelerator and it'll open it.
2000 1.8T ARZ - OEM+
joshstanvw
GTI forum regular
09 February 2014, 22:15 »
I have agu cable throttle just whipped it off cleaned it up whacked it back on and jobs a good'n no issues with alignment or anything like that
Golf mk4
Wazzzer
