Author Topic: downpipe and sport cat  (Read 3657 times)
Offline tea2112
« on: 03 February 2014, 11:27 »
Does anyone manufacture a downpipe and sports cat that will bolt up to the O.E cat back exhaust. Will the car pass an mot afterwards.
Offline bacillus
Re: downpipe and sport cat
« Reply #1 on: 03 February 2014, 14:35 »
Depending on the diameter of your down pipe, you may need a reducer sleeve to mate the downpipe with the oem cat back.
Also you should be able to pass the MOT emissions test with a 100 or 200 cel sports cat.
Without traction power is nothing!
Offline tea2112
« Reply #2 on: 03 February 2014, 15:23 »
I found a eurojet downpipe and sport cat that should mate up to the remaining O.E. exhaust system for under 500  pounds
Offline barrym381
« Reply #3 on: 03 February 2014, 19:18 »
why not just get a full custom system for a couple of hundred extra  :smiley:
Offline tea2112
« Reply #4 on: 04 February 2014, 11:13 »
Any idea's where to get a full custom exhaust for under 1000 pounds , closer to 800 if possible
Offline th3_f15t
« Reply #5 on: 04 February 2014, 12:25 »
I think AMD in Essex can do custom exhausts, although BCS do them as well, have a Google.
Moving over to Flickr, sorry for the broken picture links!
Offline tea2112
« Reply #6 on: 12 February 2014, 20:24 »
After doing a little research , I am going to remove the pre cat, free mod ,has anyone else tried this?
Offline xodia
« Reply #7 on: 17 February 2014, 01:25 »
Yeah, this mod is easy to do if you have the right tools and access, i found the hardest bit was getting the downpipe out from under the car, once i did that, knocking the cat out and putting it back easy :) made a fair difference as well :)
Offline tea2112
« Reply #8 on: 20 February 2014, 18:48 »
 Just ordered my DV+ so I will do both jobs at the same time
Offline tea2112
« Reply #9 on: 26 February 2014, 14:25 »
Just got my GTI back from my local mechanic , had my dv+ installed and my pre cat removed. The exhaust note is a little deeper and throttle response is better, also noticed a slight increase in mpg! You can tell the car is breathing better ,the turbo spools up a lot quicker. All in all very happy with the results !
