Author Topic: Cant find fog light wireing  (Read 2630 times)
Offline Shizzle
« on: 03 February 2014, 08:18 »
please help just fitted new bumper with all the lights and new splitter and vento front end is on but i cant find the fog light wiring anywhere does any 1 know where it starts or comes from so i can see if it has been cut thank you.
MK3 Golf GTI 2.0 16v 3Door Storm Grey
Offline tweed
Re: Cant find fog light wireing
« Reply #1 on: 03 February 2014, 10:49 »
It was a option.  So you need the loom and switch. Its all plug and play and been covered a few times. If you search im sure you'll find a guide
Offline Shizzle
« Reply #2 on: 03 February 2014, 11:21 »
i have the switch in the car though just no wiring ill look into it thanks.
Offline Len
« Reply #3 on: 03 February 2014, 13:26 »
We all have a switch in the car!
Its the headlight switch.
If you have the correct switch and at some time the wiring was there for the foglights then you should have a two position pull out on that switch.
First pull operates the rear fog lights only then if you pull again yo get both front and rears on.
If you dont have a twice pull switch your car was never fitted with foglights.
www.sas.org.uk
www.the-ace.org.uk
Offline tweed
« Reply #4 on: 03 February 2014, 13:33 »
 :grin: :grin: :grin: of course you have one but as len says.
Offline Shizzle
« Reply #5 on: 03 February 2014, 14:30 »
AH very help full il have a look later on thank you.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #6 on: 04 February 2014, 17:24 »
This has been covered loads of time mate, if your car wasn't equipped with front foglights from new then it will require the appropriate headlight loom section that runs from the large round plug located above the radiator and connects to the lighting and horn.
All mk3's came with the necessary wiring behind the dash so inside the car all you need is the correct headlight switch.
