Author Topic: Golf GTD ESP fault  (Read 2161 times)
Offline Critee
Golf GTD ESP fault
« on: 02 February 2014, 19:12 »
Hello could someone help me out,
Just purchased a golf gtd and started car and esp fault message appeared and had a little shudder going on! Quickly turned ignition off and then back on and car was fine,
Any ideas what problem may be or should I take to garage to be checked out?
Thanks
Offline Mattyj
Re: Golf GTD ESP fault
« Reply #1 on: 02 February 2014, 19:15 »
Its a generic intermitant fault mate will come and go don't worry about it
Offline Critee
« Reply #2 on: 02 February 2014, 19:18 »
Ok cheers
Offline Dan.B
« Reply #3 on: 03 February 2014, 01:01 »
Mine doesn't do it  :sad:
I'd say it could be a sign of low battery voltage causing it to throw a warning message after start up.
Get the battery checked.
Offline Mattyj
« Reply #4 on: 03 February 2014, 06:42 »
No dan its a known mk6 fault mine does it intermitent its fine there was a write up in it somewhere vw software issue
Offline andyr
« Reply #5 on: 03 February 2014, 10:26 »
I have to agree with Dan.B!
It may be a known fault but having had the ESP fault flash up occasionally on ign switch on (even after a long journey) after installing a new battery mid November last year it hasn't happened once since!  :smiley:
Mk VI Black Pearl GTD.... No Frills, replaced a Black Pearl PD150 Bora, which in turn replaced a Dragon Green VR6 which followed a Dusty Mauve MK III 8v Gti.
Offline Mattyj
« Reply #6 on: 03 February 2014, 10:33 »
Well thats the response i got on here when i asked never bothered me but if thats the case great regardless its nothing to worry about
Offline Critee
« Reply #7 on: 03 February 2014, 20:50 »
hasn't appeared today so could of been a one off!
Offline Mattyj
« Reply #8 on: 04 February 2014, 05:59 »
Doesn't happen everyday once a month maybe
