Author Topic: RCD510  (Read 3234 times)
Offline stanmoar
RCD510
« on: 30 January 2014, 19:53 »
Hi folks, wondered if you can help me ?
Purchased an RCD510 last year as an upgrade to the RCD310, good piece of kit but I'm having a problem
With the sound quality from the iPod connection, sounds bloody awful compared to the radio and CD playing
The same music, any ideas?
Stan
Offline Mattyj
Re: RCD510
« Reply #1 on: 30 January 2014, 20:05 »
Not really mate did same swap no probs are you using a mdi cable? Check pins connection
Offline stanmoar
Re: RCD510
« Reply #2 on: 30 January 2014, 20:17 »
I've seen something about swapping the pins but not sure which ones??
Offline Booth11
Re: RCD510
« Reply #3 on: 30 January 2014, 20:26 »
No difference in sound quality on mine at all.  As said, check your MDI cable.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Mattyj
Re: RCD510
« Reply #4 on: 30 January 2014, 21:26 »
To be fair we are both working the assumption mdi is being used could have it in the aux socket in this case i'd say again dodgy cable or connection at eithier end
Offline Booth11
Re: RCD510
« Reply #5 on: 30 January 2014, 21:40 »
Ah, yes the Aux socket, forgot about that - redundant in my car, never use the thing.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline stanmoar
Re: RCD510
« Reply #6 on: 30 January 2014, 21:41 »
Yea sorry chaps Mdi is being used, tried the one from my wife's car and sounds the same!!
Offline Booth11
Re: RCD510
« Reply #7 on: 30 January 2014, 21:45 »
Have you tried messing about with the rcd510 settings at all?  Or try doing a hard reset on your iPod.  I had some communication issues with mine and that resolved them.  Know this is not the same issue but can't hurt to try.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Booth11
Re: RCD510
« Reply #8 on: 30 January 2014, 22:11 »
Also check your aux input levels in the media set up menu.  If it is set to 'high' it can cause a lot of sound distortion, though I would expect this to affect cd's too.
Media - Set Up button - Aux input level - choice of low, medium or high.  Medium is the better setting.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Mattyj
Re: RCD510
« Reply #9 on: 31 January 2014, 06:19 »
Very strange i'd check the radio connections on the back failing tht but rcd 510 in ur wifes car to process illiminate
