Author Topic: How to stop wipers 'banging' at the end of their travel?  (Read 2491 times)
Offline russ-vdub
  • Once a Dub, Always a Dub
Is this just a case of adjusting on the spline a bit or do I need to bend something in some direction?
Offline oakgreener
Re: How to stop wipers 'banging' at the end of their travel?
« Reply #1 on: 29 January 2014, 19:14 »
Unless you have a serious problem with wear in the linkage, it is a simple fix by removing the nut and moving the arm on the spline
Offline Mr Blue
« Reply #2 on: 29 January 2014, 19:28 »
Russ send it to Luke while your at it. Only guy I trust with detailing  :grin:
Offline weazgti
« Reply #3 on: 30 January 2014, 07:41 »
You can pull the mech off the motor and turn it if it's hitting the scuttle. Also it's not hitting the plastic ecu cover is it?
Offline russ-vdub
« Reply #4 on: 30 January 2014, 12:57 »
Sorry should have mentioned its at the top of it's travel. It doesnt actually hit anything tho, it the blade like folds on itself making the 'bang'
Offline russ-vdub
« Reply #5 on: 30 January 2014, 12:58 »
Haha yeh we've been meaning to do it for ages, probs early summer now tho as the weather is too jank atm!
