Author Topic: more c/motorsport tip issues with now breather pipe issue  (Read 2798 times)
Offline davemk4
Purely a rant. So as you know not happy with my TIP but thought maybe how if fitted.....
boughy there matching breather pipe....
guess what doesnt fit it blocks the dv pipe off so again sh!t fit.
Can someone please postva picture of there set up so can see where im going wromg please as ive had enough of this problem
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline Nino
Re: more c/motorsport tip issues with now breather pipe issue
« Reply #1 on: 25 January 2014, 09:47 »
I have the same engine as you, I must admit, i did have a few problems getting the TIP fitted but anyway here is my setup. all my pipes are creation motorsport.
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline davemk4
« Reply #2 on: 25 January 2014, 11:47 »
Nino you a starvthat will be a great help! My issues is the dv return pipe which is oem at mo ends up been blocked by the new c/motorsport breatger pipe. Im going to compare your locations to mine now etc.
my blue pipe does say may need to be cut to fit.....
what hose clips d size did you use for your n75 and dv take off use?
Offline AD1.8T
« Reply #3 on: 25 January 2014, 12:33 »
Get some pictures up of the problem buddy
Offline davemk4
« Reply #4 on: 25 January 2014, 12:55 »
Offline AD1.8T
« Reply #5 on: 25 January 2014, 15:19 »
All of them metal pipes can be removed doing the sai delete
Offline davemk4
« Reply #6 on: 25 January 2014, 15:23 »
So 2nd pump etc walkthough then?
Thing is shudnt have to for the price the hose is
Offline AD1.8T
« Reply #7 on: 25 January 2014, 16:13 »
My forge one was the same if its a little bit out on the turbo it will reflect at the top
Offline davemk4
« Reply #8 on: 25 January 2014, 16:40 »
So it across the board issue then?
Offline davemk4
« Reply #9 on: 25 January 2014, 16:40 »
Seems silly having to remove all that piping and air pump for a new tip. Really hoping can get it fitted better
