Author Topic: Boot rattle - TPI?  (Read 34321 times)
Offline Mo_Nurk
Re: Boot rattle - TPI?
« Reply #40 on: 22 April 2014, 16:18 »
Thanks for the update! :) Hopefully we get a clear answer from VW UK soon
MK7 GTI DSG 5 Door, Oryx White, Performance Pack,  Keyless Entry
Offline JamesR27
« Reply #41 on: 22 April 2014, 18:10 »
I did think that if it was not sorted by the end of April I would consider rejecting the car. As the customer service is so bad, they have not even logged my phone calls and never phone me back. My dealer keeps me updated and I don't have any issues with them just VW
Does anyone know my options?
Mk 8.5 Clubsport Pure White, Queenstown, DCC.
MK 7.5 R Pure White, Pretoria Silver, DCC, Rear Camera.
Gone - MK 7 GTI Carbon Grey, Rear Camera, Service Pack.
Gone - MK 6 GTI  Reflex Silver, Monza Shadows, RCD 510, Rear Camera, Bluetooth, Tyre Pressure Sensor, Xenons Convenience pack, Service Pack :)
Gone - MK 5 GTI Reflex Silver, Monza II 18's, Luxury Pack, Mulitchanger
Offline phil_790
« Reply #42 on: 25 April 2014, 23:04 »
Hi,
I got a voicemail from VW UK today, apparently the parts have arrived to replace the shock absorbers to see if this solves the issue, gotta call them back next week to book it in at my dealers to get the work done. The way got VW UK involved was a stroppy email through the website which resulted in a follow up call a coupe of weeks later, which got the ball rolling.
With regards to rejecting a car it's a long and drawn out process, and in most cases I don't think is successful, I had lot of issues with a new Peugeot a few years ago, eventually the dealers gave in and replaced the car for more or less no additional cost to me, but the car was never officially rejected even though it had over £4k worth of warranty work done due a a number of serous problems, I think they even went on and sold the car as an "approved used" Peugeot. But at least I managed to get rid of it and the dealer principle didn't have to speak to me every week to explain why the car was still having a load of issues, I should really have listened to everyone who said at the time not to get a Peugeot, but hindsight is great!
Cheers,
Phil
Offline phil_790
« Reply #43 on: 01 May 2014, 13:36 »
Hi all,
Just a quick update, VW UK called today to say that new shock aborsbers have been received at my dealers and will be fitted to my car next week. They claim this will fix the noisy "characteristic" of the rear of the car. Will let you all know how it goes next week!
Cheers,
Phil
Offline falconmick
  • Golf MK7 R
« Reply #44 on: 24 May 2014, 20:42 »
Boot rattle was a common issue with the Scirocco - one of the 2 bump stops for the boot lid had some play in it or stuck out further than the other- maybe it's the same with yours. You might need to adjust one or both outwards a notch or 2. You had to get a small (2 or 3mm) allen key through the centre hole and loosen the stop off then pull it out a click or 2 and tighten up the allen bolt.
Monkeyhanger I owe you a beer, had a rattling noise in my boot on brand new R, been driving me mad for the four weeks I have had the car, tried all sorts of things that didn't work. Thanks to your post re  bump stops I checked mine and they were unevenly adjusted, one was about 5mm lower than the other, now sorted and rattle gone :)
Offline monkeyhanger
« Reply #45 on: 25 May 2014, 06:42 »
[/quote]
No bother. Seems as though the Germans are no better at building German cars than the Portuguese are. 5mm out from one side to the other is a huge discrepancy.
Offline phil_790
« Reply #46 on: 26 May 2014, 12:16 »
Hi all,
The car went back the other day for the rattle, which wasn't cured by the replaced shock absorbers, but low and behold the noise was coming from the boot lit...this is what I mentioned to them months ago, but hey ho. It turned out the boot lit needed adjustment, I asked if it was the bump stops (I had this issue on my old scirocco also) They claimed it wasn't that. It seems to be OK now, but I have only done about 30 miles since the car came back.
Cheers,
Phil
Offline Mo_Nurk
« Reply #47 on: 12 June 2014, 12:56 »
Thought I'd add my situation to this thread. I booked in my car at my dealers, looks like they've identified the noise to be coming from the rear shock absorbers. They'll be replaced and hopefully no more noise. Apparently it had taken them a while to pinpoint the sound. Will update when I have the car back, most likely tomorrow.
Offline JamesR27
« Reply #48 on: 12 June 2014, 20:32 »
I had a phone call from the dealers yesterday to say they finally had a TPI number.
They have supplied an mp3 file to the dealers to compare against our rattles. Mine is booked in on Tuesday so will see if it matches. If it does then it's a rear damper swap to up rated parts.
Offline Mo_Nurk
« Reply #49 on: 18 June 2014, 18:04 »
Finally got the car back, took a while for the parts to come down... And I'm happy to report that pesky rattle no longer ermmmm rattles.
It did turn out to be the rear shock absorbers.
