Author Topic: Crack in my gearbox oil every where help please  (Read 2414 times)
Offline wolfie1981
« on: 24 January 2014, 00:23 »
 I've cracked my gearbox on my 18t agu oil has run every where not sure how big the crack is but need the car to get me to the end of the month before the paint shop.
I'm going to try JB WELD to seal it.
My question is 1 where's the drainage plug.
2 the filler plug
3 the bleed nipple to get all the air out after I seal it.
Just hope this jb weld will hold till the end of the month. Or is there a other brand better to try
Any help will be great guys
Offline wolfie1981
Re: Crack in my gearbox oil every where help please
« Reply #1 on: 24 January 2014, 00:38 »
It's defo gearbox people not engine oil lol
Offline Nino
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline wolfie1981
« Reply #3 on: 24 January 2014, 10:16 »
Quick update been to a mates garage to get the car up on the ramp. Oil pissing out the gearbox along will metal shavings so looks like need a new gear box and clue to what may have caused this??
« Last Edit: 24 January 2014, 11:17 by wolfie1981 »
Offline wolfie1981
What gearbox will fit my 18t agu?
« Reply #4 on: 24 January 2014, 11:23 »
As above what gearbox will fit my agu 1.8t golf??
Last nite I noticed the clutch pedal got soft on the way to work.
After leaving work notice oil over the road. Took alook to fined gearbox oil running from the bottom of the box I was thinking I may have hit something in the road as my car is low on coilovers.
Anyway had the car towed to mates garage this morning to get it up on the ramp to find oil still coming out with metal shavings I take it I will need a gear box?. But which one??
« Reply #5 on: 24 January 2014, 11:23 »
Your best bet is a s/h gearbox, sounds like a bearing has broken up.
Re: What gearbox will fit my 18t agu?
« Reply #6 on: 24 January 2014, 11:24 »
I am sure it needs to another 1.8t box.
Offline dom
  • Back in a Mk4
« Reply #7 on: 24 January 2014, 13:11 »
I've merged the two threads, it seems pointless having 2
Offline wolfie1981
« Reply #8 on: 24 January 2014, 18:04 »
Right guys found a gearbox at a breakers over here in belfast where I live for £135 delivered it's coming Monday.
The breakers told me down the phone the box is from a AGU so I take it that it's going to fit.
But also been reading there are a couple of different types of box for a AGU is this correct??
Offline joshstanvw
« Reply #9 on: 28 January 2014, 17:17 »
In regard to physically fitting and working all mk4 5 speed should bolt in and work it's just the ratios that differ I was considering a diesel box but the ratios would have been detrimental due to the short rev range and high torque of a diesel a 2.slow gti one will fit also and ratios are very similar from what I can see so long story short the one from the agu will fit like a glove I did mine on my driveway in the rain in 3 days (an hour or 2 a day)
GTI is not a trim level. It is a lifestyle.
1999 1.8t AGU, KO3s, forge 007p, silicone tip and charge pipe, oil catch can, SS turbo back system, pipercross CAI, g60/vr6 clutch, 40mm apex springs, drilled and grooved discs, stage 2 remap.
