Author Topic: Next problem - Exhaust!  (Read 8661 times)
Offline Len
« on: 21 January 2014, 12:34 »
I know the new exhaust manifold will not fit my existing system!
I have options.
1. Cut the two bolt flange off the old down pipe and weld it onto the end of the new downpipe. (stainless to mild weld)
2. Use the supplied piece of straight pipe which I think will replace the CAT. Still have to find out if its long enough!
3. Cut the two bolt flange off the front end of the CAT and cut supplied length of pipe and weld up.
Not sure what I want to do or can do!!!
Do I really want to run de-catted???
Yes it would improve performance.
Suggestions??
www.sas.org.uk
www.the-ace.org.uk
Offline itavaltalainen
Re: Next problem - Exhaust!
« Reply #1 on: 21 January 2014, 13:45 »
get a stainless steel reducer (there's a guy that stretches pipe made to measure) cut front silencer pipe a bit shorter.... weld the reducer bit on the use the dual clamp to fit to cat....
Offline Len
« Reply #2 on: 21 January 2014, 19:34 »
I can see I am going to have to take some piccies!
The CAT has the flat plate with two bolt holes.
www.sas.org.uk
www.the-ace.org.uk
Offline tweed
« Reply #3 on: 21 January 2014, 22:20 »
Whats the problem?  Why cant you fit a abf exhaust?
Offline Len
« Reply #4 on: 22 January 2014, 12:49 »
Not following this are you and yet you comment! :rolleyes:
Its a Supersprint tubular exhaust manifold and down pipe 4in2in1.
Which is necessitated by the 2.1litre engine with flowed & ported head
www.sas.org.uk
www.the-ace.org.uk
Offline tweed
« Reply #5 on: 22 January 2014, 12:58 »
So supersprint system for a abf/vr6 (2.8) is not going to fit?
Offline tweed
« Reply #6 on: 22 January 2014, 13:02 »
Im following just dont under stand why you cant fit a exhaust.
And you still haven't explained why.
Just trying to help but you shoot me down.
Top bloke you are.
Offline Foreveryoungaus16v
« Reply #7 on: 22 January 2014, 13:05 »
Don't worry Wheel Specialist you are always a lot of help to me :smiley:
163 BHP (TSR POWER RUN)
Offline Len
« Reply #8 on: 22 January 2014, 13:20 »
I have tried to explain in the first post!
If you cannot understand what the problem is then I will have to post pictures.
It fits onto the head its the other end.
The Italians assume I am going to run de-catted and I am not sure yet!
Also it doesnt look like the de-cat pipe is long enough. (but I am yet to check that)
www.sas.org.uk
www.the-ace.org.uk
Offline tweed
« Reply #9 on: 22 January 2014, 14:31 »
I have a standard stanless flange that I made to fit a aftermarket manifold. I gasket matched it but made the inside diameter bigger to fit the aftermarket manifold.
I still have it as I sold the car.
Cant you make a flange? Its not hard.
