Author Topic: Next problem - Exhaust!  (Read 8636 times)
Offline Len
Re: Next problem - Exhaust!
« Reply #30 on: 26 January 2014, 18:15 »
Well its fitted, well nearly!
Just need to sort out a fitting between the end of the down pipe and the straight pipe.
And get some heat wrap, which I definitely need!
www.sas.org.uk
www.the-ace.org.uk
Offline tweed
« Reply #31 on: 26 January 2014, 19:35 »
I would make a flange and weld it on as I did. You will be able to fit cat or de cat.
Also soak the wrap in water then wrap the exhaust.  It will dry tight. I also put stainless steel tie wraps every 10"
Offline Len
« Reply #32 on: 27 January 2014, 20:31 »
Getting that done tomorrow! :afro:
www.sas.org.uk
www.the-ace.org.uk
Offline tweed
« Reply #33 on: 27 January 2014, 20:55 »
Sweet
Offline Len
« Reply #34 on: 28 January 2014, 20:56 »
But have decided the manifold aint right so will be coming off again!
www.sas.org.uk
www.the-ace.org.uk
Offline xionsolaris
« Reply #35 on: 28 January 2014, 23:54 »
any chance of pics when complete or progress intrested  :shocked:
Offline Len
« Reply #36 on: 29 January 2014, 12:29 »
Have posted some progress pics up in my Dub Rides thread.
But if you mean pics of this problem, I havent taken any. Doubt you would see much in a shot from above and from underneath is a bit cramped!
Although if I am working on trying to move or adapt the steering rack then the car will have to get lifted up a lot higher!
www.sas.org.uk
www.the-ace.org.uk
Offline Len
« Reply #37 on: 06 February 2014, 13:43 »
SORTED!
Found a local chap on recommendation from Billy's brother and he has done a massive job on it!
has cost me but at least it will now fit!
www.sas.org.uk
www.the-ace.org.uk
