Author Topic: Need to replace 3 tyres - thoughts  (Read 5986 times)
Offline VWNOS
« on: 20 January 2014, 06:53 »
My GTi has Conti Sport Contact 2's all around. They're a bit hard (noisy) but always been happy with them. I need to replace the fronts and was planning to fit Michelins.
Had a look at the rears yesterday and one of them has about 4mm left and the order 7mm (had to replace it due to a puncture), so now I'm thinking of replacing the 4mm tyre also, so I've near-new boots all around. Will keep the 4mm as a spare incase I get another puncture!
I don't want mixed tyres on the same axle, so would you:
1) fit 3 x new Conti Sport Contact 2's, or
2) replace the rear tyre with another Conti 2, and put Michelins (or similar) on the front
Any thoughts?
Offline Mattyj
Re: Need to replace 3 tyres - thoughts
« Reply #1 on: 20 January 2014, 07:23 »
Personally i wouldn't bother with michelins great tyre but too soft and a bit pricey i'd get another set of contis myself i'm running fk453's happy enough with those on a gtd
Offline dubber36
« Reply #2 on: 20 January 2014, 07:55 »
If you want Michelins, I'd put two new Michelins on the rear and your 7mm Conti, along with a new one to match on the front. 7mm is as good as new, so there shouldn't be any imbalance at the front.
It is good practice to fit new tyres to the rear of a front wheel drive car, plus the Contis will wear faster on the front, meaning you'll be able to buy another pair of Michelins to match sooner, having got your moneys worth from the Contis.
Offline VWNOS
« Reply #3 on: 20 January 2014, 09:06 »
Thanks chaps. Have decided to stick with the Contis this time.
Offline charlie
« Reply #4 on: 20 January 2014, 09:45 »
Good choice :cool:
2012 black pearl Golf gti mark 6 5 door leather cruise 510rns bluetooth acc dab sunroof park assist rear camera parking sensors storage pack and the luxury pack :-) sold :/( now aiming a 2013 passat alltrack
Offline Booth11
« Reply #5 on: 20 January 2014, 09:48 »
On a similar note (sorry to hijack your thread), I need to replace just 1 tyre, so looking for a bit of advice.
Front o/s tyre needs replacing due to wear, n/s front tyre is only 4 months old (replaced due to puncture), rear tyres have plenty of tread left.  So the plan is to swap the rears to the front and put new tyre and nearly new tyre on the rear.   Is the best thing to do?  All contisport contact 5's.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline VWNOS
« Reply #6 on: 20 January 2014, 11:24 »
Yes, makes sense. I was previously told by a Bridgestone tech to switch tyres front to back diagonally, to even out tyre wear (rather than swap on the same side).
Offline Mattyj
« Reply #7 on: 20 January 2014, 11:26 »
Sounds good to me mate
Offline Mattyj
« Reply #8 on: 20 January 2014, 11:27 »
Thats ok if non directional
Offline Booth11
« Reply #9 on: 20 January 2014, 11:41 »
Yes, was just going to make that point.  ContiSportContact 5p's are asymmetrical so can't do that.  Can be swapped to front but must be on same side.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
