Author Topic: Need to replace 3 tyres - thoughts  (Read 5990 times)
Offline charlie
Re: Need to replace 3 tyres - thoughts
« Reply #20 on: 20 January 2014, 20:48 »
Last time I had tyres was on my previous gti told the fitter wheels are perfect and when you fit them I want them back perfect he did a good job so all I think you have to do is point it out to them and all should be ok hopefully :whistle:
I agree charlie, but it somewhat undermines that statement when the wheels are kerbed and not perfect.  I will however point out that, despite the existing marks, I still expect care to be taken and no additional damage to be inflicted through the fitting process.
You only have to look at a Glendale and it marks  :wink:
i can imagine monzas aren't much better  :smiley:
2012 black pearl Golf gti mark 6 5 door leather cruise 510rns bluetooth acc dab sunroof park assist rear camera parking sensors storage pack and the luxury pack :-) sold :/( now aiming a 2013 passat alltrack
Offline Red Tornado
« Reply #21 on: 21 January 2014, 00:27 »
Yes, makes sense. I was previously told by a Bridgestone tech to switch tyres front to back diagonally, to even out tyre wear (rather than swap on the same side).
Thats ok if non directional
Yes, was just going to make that point.  ContiSportContact 5p's are asymmetrical so can't do that.  Can be swapped to front but must be on same side.
Asymmetric tyres can be swapped front to back diagonally as an asymmetric tyre has a clearly defined inside and outside edge (check your tyre's sidewall) whereas a directional tyre (think the original Goodyear Eagle F1 GSD3 with the 'arrowhead' tread pattern) can only safely rotate in one direction ie the direction the tread points (usually depicted by an arrow on the tyre sidewall), for optimum water dispersal, so needs to stay on the same side if swapped, otherwise the tread would be pointing in the wrong direction as it were.
So your Conti SC5s could be swapped front to back and to the opposite side (the outside part of the tyre will still be on the outside) if it helped even out tyre wear :smiley:
2014 Mk7 GTI - 5 dr, DSG, Performance Pack, Winter Pack, Dynaudio, Dynamic chassis control, Rear side airbags/seat belt warning system, Tornado Red.
Offline Booth11
« Reply #22 on: 21 January 2014, 08:03 »
Cheers for the info  :smiley:  yes, I was confusing directional and asymmetric.  It is only directional tyres that cannot be cross rotated.
« Last Edit: 21 January 2014, 08:26 by Booth11 »
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
