Author Topic: Relays/Fusebox Problem  (Read 4238 times)
Offline benday007
« on: 19 January 2014, 17:53 »
Hi Guys, After an afternoon of "working" on my project mk2 8v (1989)
I noticed that most of the relays on the right and side of the fusebox are rusted into the box by their contact pins.
I've removed all of the relays to clean em up, however, one did not come out in one piece as it was rusted in so badly, in fact, one of the contact pins broke off and stayed inside the slot on the fusebox. It is not sticking out at all so wouldn't be able to remove it with tweezers/pliers as can't get on it from the front, also its rusted in there so it will be stuck fast too.
So does anyone have a magical, easy solution to getting the pin out so that I can put a new relay in. Or is it a case of taking the fusebox totally out of the car - can it be opended up when out of the car??
Otherwise, how much petrol do I need to set the magic machine alight, that'll teach it.. :)
Offline weazgti
Re: Relays/Fusebox Problem
« Reply #1 on: 19 January 2014, 18:11 »
I picked up a mk3 fusebox from scrappy for £7 for mine. Might be an easier solution for you
Offline benday007
« Reply #2 on: 19 January 2014, 18:22 »
Is it an easy job to change it over?
Offline Sgt_Lemon
  • 8v owners club
« Reply #3 on: 19 January 2014, 18:29 »
The fuse box is the same. If you take the three screws out of the cover under the wheel you can see it all. There are clips on either side of the box which when undone allows the box to flip down and be supported on the wires. You can take your time and label/photo everything to put them in the new box. They can be a bit of a mare to get out sometimes. Instillation is the reverse of removal.
Offline weazgti
« Reply #4 on: 19 January 2014, 19:01 »
I messed about changing one plug at a time but then run out if room and just unplugged everything. The beauty is the plugs will only go in the correct slot with offset pegs on them so no chance of getting it wrong
Offline benday007
« Reply #5 on: 19 January 2014, 19:04 »
Ive got the lower dash trim panel off already, the fusebox pulls away towards me and there are white clips on either side which I think I need to unclip, how can you get to the plus on the back of the fuse box?
Offline weazgti
« Reply #6 on: 19 January 2014, 19:19 »
Pull the clips out and lift fusebox off its hangers then you ll be able to spin the whole thing over
Offline benday007
« Reply #7 on: 20 January 2014, 00:49 »
so, once I've removed the fusebox from the car, is there a chance I can get to the back of the slot the pin is stuck in? does it split in half as such or is it a sealed unit.
I don't mind buying a replacement, but I'd rather remove the pin, clean the box up and put it back if that is possible, no sense wasting money if I don't need too
What are ya thoughts?
Offline Sgt_Lemon
  • 8v owners club
« Reply #8 on: 20 January 2014, 19:13 »
Even if it was possible to get it in half to push the relay pin back through your still missing a relay and would have most likely have to have removed all the plugs. At the scrappy grab both the relay and the fusebox.
Offline gazareth
« Reply #9 on: 20 January 2014, 20:13 »
I would just change it as going by your first post it sounds pretty corroded. is your car a ce1 or ce2 model? ce1 will have hazard light switch beside rear fog light switch. ce2 its on steering column cowl.
