Author Topic: Anyone removed there front arch linings??  (Read 1424 times)
Offline rfn_hodgson
« on: 17 January 2014, 18:44 »
I had to remove mine as it had just deteriorated to nothing and was wondering if the problem with my soaked cabin filter could have anything to do with this
VW Golf MK4 1.8 Turbo AUQ 203 BHP-more now :) , ultimate vacuum delete, Forgre 007p-new piston, Oil catch can, s3 boost set up, FMIC, silicone TIP, full turbo back exhaust, stage 1 map, lowered on V-maxx coilovers  audi tt Quattro alloys
Offline rfn_hodgson
Re: Anyone removed there front arch linings??
« Reply #1 on: 20 January 2014, 18:09 »
Anyone?
Offline dom
  • Back in a Mk4
« Reply #2 on: 20 January 2014, 18:51 »
Why did you completely remove them? Mine are almost worn through at the bottoms but I wouldn't remove the whole thing just because of that.
Offline rfn_hodgson
« Reply #3 on: 20 January 2014, 19:04 »
They were starting to come loose on the sides and we're flapping by the end of it :( so I just removed them and problem solved..... But another one arises :(
Offline Nino
« Reply #4 on: 20 January 2014, 20:38 »
well my wheel ripped half of my drivers one apart, does that count? :P
Current - MK6 GTi Edition 35 - Candy White - 3 door
« Reply #5 on: 20 January 2014, 21:53 »
Better off to replace them, the amount of crap you collect without them is unreal
Offline mcgee9t2
« Reply #6 on: 20 January 2014, 22:09 »
+1. Also isn't the back of the arch waxed not painted. Therefore when stones and sh!t flicks up inside the arch it could take the wax off and leave bare metal. Which could then rust from the inside out?
Could be wrong on this though...
« Reply #7 on: 20 January 2014, 22:17 »
I think you could be correct, the mk5 suffers as the arch liner rubs through the wax and they start rusting.
Bmw's and Merc's around the same age suffer big time from the same issue
« Last Edit: 20 January 2014, 22:19 by Wayne »
Offline Luke1981
« Reply #8 on: 21 January 2014, 10:12 »
This is correct. My front nearside wing has blistering caused by rust from the inside of the arch. I took it to VW as they stated that there is a 10 year paint guarantee.  Was told this is a common problem with the MK4 as stated above. Because of the fact that the vehicle had no paint service in the past that I wasn't covered.  Eventually I will need to replace the wing or take it off and get it treated and resprayed.
MK IV GT TDI 150 PD / MKII CADDY SDI
