Author Topic: How to fix speakers  (Read 2530 times)
Offline madgemad
How to fix speakers
« on: 15 January 2014, 22:47 »
Hey,
No doubt this has probably been asked before....
I have a mk4 golf gti and have just had a new window regulator fitted to the front offside door, however now my speaker doesn't work. I am fairly sure the panel came with the speaker attached so there is no way of me telling if the speaker worked to begin with.
How do I figure out what is wrong with it and is it likely that I can fix it?
I know how to get the door panel off but don't know where to go from there...
Thanks
Offline mcgee9t2
Re: How to fix speakers
« Reply #1 on: 17 January 2014, 12:33 »
have you defanitly plugged the speaker in?
and you havent snaped a wire off the harness when replacing the regulator panel.
if you still have the old regulator panel, try plug the speaker on that panel in and see if it works.
Offline madgemad
« Reply #2 on: 17 January 2014, 17:27 »
I didn't fit it so I'm not sure. Will hopefully have time to take the panel off and had a look, just be good to know what i'm doing if it isn't as simple as being plugged in....
Managed to get the old ones back but I have been told they were left in the rain :/
Thanks
