Author Topic: GTD mid-range power loss and engine warnings!  (Read 2138 times)
Offline branchespark
« on: 15 January 2014, 15:11 »
Hi.
My 2010 GTD has developed an annoying fault. The mid-range (1,000-2,500rpm) is rather flat and then the turbo kicks in. I also get a warning from the engine, so out comes VCDS!
My local garage want to charge a fortune to looking at the car, so I thought I'd ask the opinion of you guys before I drop some cash.
As I understand it, the issue can be one or all of the following:
  • boost pressure pipe come off (but turbo does work at high revs)
  • boost pressure pipe leaking (plausible, as higher pressure makes turbo work?)
  • boost actuator faulty (again, can it work 'some of the time'?)
  • wastegate sticky
  • some other sensor?
The error is as follows:
Code: [Select]
Address 01: Engine (CBB)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 LC    HW: 03L 906 022 G
   Component: R4 2,0L EDC G000SG  6655
   Revision: 13H03---    Serial number:
   Coding: 0001072
   Shop #: WSC 01357 011 00200
   VCID: 71EC582168DBFB966BD-8024
1 Fault Found:
000665 - Boost Pressure Regulation
               P0299 - 000 - Control Range Not Reached
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 111275 km
                    Time Indication: 0
                    Date: 2042.14.31
                    Time: 06:43:14
             Freeze Frame:
                    RPM: 2208 /min
                    Speed: 75.0 km/h
                    Load: 47.8 %
                    Absolute Pres.: 1856.4 mbar
                    Absolute Pres.: 1244.4 mbar
                    Lambda: 98.6 %
                    Lambda: 43.4 %
Readiness: 0 0 0 0 0
Is there any quick check I can do to try and see what the issue might be? I like to be an informed customer and may even be able to do the work myself.
Thanks a lots,
Sam
Mk6 GTD 5dr | Manual | Deep Pearl Black | 18" Vancouvers | Leather | Xenons | RNS510* + VW Premium Bluetooth (iPhone4) + Dynaudio | Smoked LED tails | Cruise
Offline Poached
Re: GTD mid-range power loss and engine warnings!
« Reply #1 on: 15 January 2014, 18:24 »
Some info here:
http://www.golfgtiforum.co.uk/index.php?topic=259326.0
You can check the pipes yourself and do some logging with VCDS as per info in the linked thread. Could take it to a tuner and have it run on the Dyno for diagnosis as well.
Offline mike.
« Reply #2 on: 15 January 2014, 20:46 »
** Delete
« Last Edit: 15 January 2014, 20:48 by mike. »
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
