Author Topic: Blowing only cold air  (Read 6647 times)
Offline russ-vdub
  • Once a Dub, Always a Dub
Re: Blowing only cold air
« Reply #20 on: 28 January 2014, 12:06 »
Which one is the matrix return Blue? Also, I'm good mates with Whittz! hi :)
« Last Edit: 28 January 2014, 18:31 by Mr Blue »
Offline Mr Blue
« Reply #21 on: 28 January 2014, 18:32 »
Ohh yes I know  :tongue: A very good mate of mine  :smiley:
IIRC the metal pipe that joins to the matrix -leave that pipe on and remove other.
Offline Diamond Hell
  • Opinions я Us
« Reply #22 on: 29 January 2014, 11:02 »
Go find a Golf3 1.8 or 2.0 in the scrapyard and rob the pipes that run to the heater matrix in the bulkhead.  Replace your pipes with these and avoid 22mm copper inserts in your system.
No heat is usually the bloody valves seizing up.  I drove from Brighton to Bristol one January in a Syncro with this issue.  A car with NO heat is a hateful thing!
Offline russ-vdub
« Reply #23 on: 30 January 2014, 13:00 »
Wicked, I've got a leak atm so when that's fixed I'll bleeding this way.
« Last Edit: 30 January 2014, 15:39 by russ-vdub »
Offline dragonfly
« Reply #24 on: 30 January 2014, 14:44 »
Straight pipes are available from VW Heritage.
