Author Topic: Blowing only cold air  (Read 6649 times)
Offline Sgt_Lemon
  • 8v owners club
Re: Blowing only cold air
« Reply #10 on: 16 January 2014, 18:05 »
I had heat again today. Having to top the coolant up everyday as it's draining over night. That's only just started happening the last 2 days (after the initial ice over and no heat). Luckily it's got stains on the drive so it's an external leak somewhere, just need to find out where.
Offline Gambit
« Reply #11 on: 16 January 2014, 20:39 »
Well just run the car up to temp and watch where its coming from :)
Offline Sgt_Lemon
  • 8v owners club
« Reply #12 on: 16 January 2014, 21:51 »
It's a slight leak though, maybe 200ml over a few hours. I saw the coolant bottle dripping when I filled it up again. Hoping its that. Raining so heavily as well makes it hard to see when and water is coming from.
Offline Steve b
« Reply #13 on: 17 January 2014, 10:20 »
If your getting moisture int he car, then the heater matrix has probably split alreay, and the blower is carrying the moisture into the cabin.
you need to swap your heater matrix and remove the bypass valves. I did mine on my 3rd mk2 only a month ago and the difference is amazing, nice warm air and after repairing the flaps, the air blows through stronger too. Its a sod of a job tho!
Offline russ-vdub
  • Once a Dub, Always a Dub
« Reply #14 on: 17 January 2014, 13:51 »
Offline jeynesey
  • Non VW but still VAG
« Reply #15 on: 17 January 2014, 16:49 »
I had the same issue, my water pump had collapsed, hence the warning light.
Offline weazgti
« Reply #16 on: 17 January 2014, 17:40 »
Aluminium tape on the heater vents with it all still in car worked for me.
Offline caprigreen
« Reply #17 on: 18 January 2014, 11:29 »
Thats a good idea, can you access easily ?
64 plate VW Golf GTI PP Pure white
1991 VW Golf GTI 8v Silver, 30k miles
Offline weazgti
« Reply #18 on: 18 January 2014, 13:24 »
Need to pull the central vents out, centre console and then the t shirt shaped bit that's behind the middle vents (sorry haven't a clue what it's called lol) and then the flaps are accessible
Offline Mr Blue
« Reply #19 on: 18 January 2014, 17:50 »
Yes it does have this valve. Another symptom I have remembered is that occasionally the temp light would flash signifying low coolant (coolant is fine) or overheating which it's not. It will flash from first ignition till i get there without turning off but often if I switch it on and off it will go off and stay off. I had considered an air lock also so will try to flush that out now.
First I would bin those valves. 22mm copper pipe to delete these.
Next you need to fit a blue coolant cap if you haven't got this already and be sure that the O ring is fitted to the cap.
Had this on many mk2's where the black cap would not release pressure and cause pipes to blow/ weak corroded core plugs to leak.
Take the radiator out and give it a good inspection. A small weep is enough to cause this exact problem
Bleed the system and add a very strong mix of coolant.
When bleeding mk2's I always disconnect the water flow exit pipe from the matrix and wait for a nice flow of water to come out. Then connect the pipe and do the same with the radiator. Speeds things up.
