Author Topic: GTD....power upgrades  (Read 2338 times)
Offline Dan.B
« on: 13 January 2014, 23:28 »
Hi all,
I have a GTD DSG. It's running a stage 1 remap with DPF delete.
What is my next step to up the power some more? Will I need to DSG remapped to handle the extra power?
Thanks
Dan
Offline SRGTD
Re: GTD....power upgrades
« Reply #1 on: 14 January 2014, 00:30 »
Don't know what your next step is for more power or whether your car is old enough to need an MOT. However, removal of the DPF may cause you an issue, come MOT time.
After Feb 2014, removal of the DPF looks as if it will mean an MOT fail, and may result in a fine, as removal of the DPF will mean non-compliance with the euro emissions standards ; see article at the link below;
https://www.gov.uk/government/uploads/system/uploads/attachment_data/file/263018/diesel-particulate-filters-guidance.pdf
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline Raffe
« Reply #2 on: 14 January 2014, 06:56 »
Hi all,
Thanks
Dan
Have you got the DPF delete map as I believe this gives slightly more power, circa 220bhp.
Offline Dan.B
« Reply #3 on: 14 January 2014, 11:29 »
Yes it had the DPF delete and map at the same time.
It's not slow to be honest but just wanted to see if there is anything else I can do.
Anyone running 'stage 2'? If so, what mods have you done?
Offline M3 SHAM
« Reply #4 on: 14 January 2014, 12:37 »
As mentioned above I would perhaps be more concerned at this point about your DPF delete.  This is going to be catching a lot of people out post feb!
Offline Poached
« Reply #5 on: 14 January 2014, 13:51 »
Probably looking at a hybrid or new turbo and associated upgrades e.g fueling and intercooler. Probably not worth it with the MPG drop?
Then theirs handling upgrades too.
As others have mentioned, no dpf might be a problem in the future.
Offline Dan.B
« Reply #6 on: 14 January 2014, 19:43 »
Ok.. I think I will have a look into handling mods.
Let me worry about the DPF  :cool:
Offline dubber36
« Reply #7 on: 15 January 2014, 07:39 »
Most people know a friendly tester. There are enough petrol cars running around without cats. I can't see DPF's being much different, except newer cars that smoke on the road are going to stand out like sore thumbs.
