Author Topic: front passenger door speaker not working  (Read 4366 times)
Offline Shizzle
« on: 07 January 2014, 20:21 »
Well one day speaker stopped working had stereo out nothing there had speaker out all wires are Ok I checked door plug seems good anything els it could be.
MK3 Golf GTI 2.0 16v 3Door Storm Grey
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: front passenger door speaker not working
« Reply #1 on: 07 January 2014, 20:28 »
I know you said you checked the plug but did you check the wires inside the rubber bellow between the door and plug. My drivers door one was broken when I got it. Failing that if you're still running the stock speakers it may well have died. ...thryre bloody old now.
Offline Shizzle
« Reply #2 on: 07 January 2014, 21:14 »
I have after market plug and play sonys I will attempt to get that rubber apart to have a look tomorrow thank you.
Offline Len
« Reply #3 on: 08 January 2014, 11:03 »
It unscrews from the A pillar. Well just a slight turn
www.sas.org.uk
www.the-ace.org.uk
Offline itavaltalainen
« Reply #4 on: 08 January 2014, 20:37 »
Yup, gonna be broken in the door rubber thing.... had 5 broken wires in total there on my 2 mk3's over the years...
VW BUSH
« Reply #5 on: 08 January 2014, 21:00 »
To true, my last golf had a piece of special cable put in both doors and boot.
It snaps inside the insulation most times and you tend to break others playing around with it :grin:
Offline xionsolaris
« Reply #6 on: 08 January 2014, 21:11 »
slightly off topic but somewhat relevant my drivers window stopped working that snapped in the flexi door joint
Offline Shizzle
« Reply #7 on: 08 January 2014, 21:28 »
I will be super careful when I get a chance to look  :smiley:
« Reply #8 on: 09 January 2014, 00:37 »
Yep, had that one as well. :whistle:
Offline rg2013
« Reply #9 on: 17 January 2014, 13:54 »
Have you checked the wires yet? I'm going to have to look at mine soon, driver side not working although I have original speakers still. May try pass side speaker in driver side as that still works, if that's easier to do than check inside that black rubber piping
1. 1995 Flash Red Corrado VR6
2. 1997 Mystic Blue Golf VR6
CCGB #4616
