Author Topic: Anyone with a Post BW45 car got VCDS?  (Read 47626 times)
Offline noobmonkey
Re: Anyone with a Post BW45 car got VCDS?
« Reply #90 on: 12 January 2014, 14:56 »
@noobmonkey
Could you share your Cent. Elec. long coding?
That could help me pointing out the bit for unfolding mirrors.
0 = 03000A42C24122FB0BA44080B10C0728100A000000000000000000000000
1 = 0E4DDD
2 = 00A8DD
VW Golf MK7 GTD Manual 5DR Pure White
Offline noobmonkey
« Reply #91 on: 12 January 2014, 15:00 »
This one looks interesting
Ok... that didn't work, stopped them closing on lock, lol! (edit - reversed and working fine again!)
Offline bloody2k
« Reply #92 on: 12 January 2014, 15:08 »
@noobmonkey
1 = 0E4DDD
2 = 00A8DD
The only difference between yours and Jasons is the last A. Both you and I have that A, but Jason got 00 in that byte.
Have you tried changing this?
Offline noobmonkey
« Reply #93 on: 12 January 2014, 15:11 »
Just for info, screenshots of my long code screen (First one):
Offline noobmonkey
« Reply #94 on: 12 January 2014, 15:13 »
@noobmonkey
1 = 0E4DDD
2 = 00A8DD
Hmm according to my screenshots above, that points at these?!
Offline noobmonkey
« Reply #95 on: 12 January 2014, 15:19 »
Yup 00 - looks like this:
Not trying it as it does not look right...
Offline bloody2k
« Reply #96 on: 12 January 2014, 15:23 »
Then I guess it's not that, which makes the difference.
I really wouldn't know what else to look for.
I would like Jason to confirm his car to unfold on unlocking.
Offline jmc
« Reply #97 on: 12 January 2014, 15:27 »
If you need me to do any thing else just fire away as I'm home now, and yes my mirrors unfold on unlocking
Jason
VW Golf VII, GTD, manual, Night Blue, Rear view camera.
Offline noobmonkey
« Reply #98 on: 12 January 2014, 15:31 »
i think we are in the right area, but i suppose i need to learn how to do a full extract of everything, + all long codings and then compare.... must be visible (If we can do that?)
Can you confirm your long coding screens look like mine for starters? :)
Offline jivemonkey
« Reply #99 on: 12 January 2014, 16:48 »
The long coding is extracted when doing an autoscan, it will be listed under the individual controller, whereas the channel mapping can be collected by using the Controller Channel Map tool in the Applications section of VCDS.
I compared the channels on the Central Electrics and nothing jumped out apart from the one previously mentioned. Might be worth checking the adaptation channels in the door controllers (42/52), apart from that, I'm struggling to see where else this can be done!
Golf VII GTD | 5dr DSG | Deep Pearl Black | Dynaudio | Winter Pack | High Beam Assist | "Advanced" Phone Prep
