Author Topic: Anyone with a Post BW45 car got VCDS?  (Read 47605 times)
Offline jivemonkey
Re: Anyone with a Post BW45 car got VCDS?
« Reply #110 on: 13 January 2014, 12:57 »
This is my BW50 with mirror un-fold on unlock:
Address 42: Door Elect, Driver (J386)       Labels: None
   Part No SW: 5Q0 959 593 B    HW: 5Q0 959 593 B
   Component: TSG FS        020 0025
   Serial number: 24111306070150
   Coding: 003F1220D001040100001000
   Shop #: WSC 01357 011 00200
   ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 4084BB7DDB7EA31ED43-8015
No fault code found.
Address 52: Door Elect, Pass. (J387)       Labels: None
   Part No SW: 5Q0 959 592 B    HW: 5Q0 959 592 B
   Component: TSG BFS       020 0025
   Serial number: 18111306070985
   Coding: 003F1020DE01040100801000
   ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   VCID: 3F86B881A680DCE6AD9-806A
Comparing with my non-unfolding:
42:
Me:      003F0220D001048000001000
Kevin:  003F1220D001040100001000
52:
Me:      003F0020DE01048000801000
Kevin:  003F1020DE01040100801000
Couple of possibilities..what they actually do though is another matter!
A little confused now, just checked earlier in the thread at JMC's coding for door controllers and it's the same as my pre-45.
« Last Edit: 13 January 2014, 13:03 by jivemonkey »
Golf VII GTD | 5dr DSG | Deep Pearl Black | Dynaudio | Winter Pack | High Beam Assist | "Advanced" Phone Prep
Offline kevinm
« Reply #111 on: 13 January 2014, 17:14 »
Thank you kevin, at work at the moment, but will confirm this evening :) - thank you!
Are you able to provide the long code for cent elec too? (09) :)
Ask and you shall receive  :laugh:
Address 09: Cent. Elect.        Labels: None
   Part No SW: 5Q0 937 084 AE    HW: 5Q0 937 084 AE
   Component: BCM MQBAB H   H16 0124
   Coding: 03011E46C20122FB0B244080B11C07281800000000000000000000000000
   ASAM Dataset: EV_BCMCONTI 012001
   ROD: EV_BCMBOSCH_VW37.rod
   VCID: 7BFE0C91F21800C6C11-802E
   Subsystem 1 - Part No SW: 5G2 955 119 A    HW: 5G2 955 119 A
   Component: WWS    131121  042 0551
   Serial number:         131123075337
   Coding: 0E4DDD
   Subsystem 2 - Part No SW: 5Q0 955 547     HW: 5Q0 955 547
   Component: RLFS  024 0042
   Serial number: Y13M07D06H08M39S56S1
   Coding: 00A8DD
   Subsystem 3 - Part No: 5Q0 951 172
   Component: Sensor, DWA
Current: His: 2020 M340i   Hers: 2019 GTD
Previous:
2014 GTI PP DSG
GTI ED30 DSG
Offline kevinm
« Reply #112 on: 13 January 2014, 17:16 »
42:
52:
Good spot. Pity there is no label file to check what each bit does.
Previous:
2014 GTI PP DSG
GTI ED30 DSG
Offline noobmonkey
« Reply #113 on: 13 January 2014, 18:03 »
   Coding: 0E4DDD
   Coding: 00A8DD
oOOoOOoOOO
That is quite different!!
kevinm
03 01 1E 46 C2 01 22 FB 0B 24 40 80 B1 1C 07 28 18 00 000000000000000000000000
JMC
03 00 0A 42 C2 41 22 FB 0B A4 40 80 B1 0C 07 28 10 00 000000000000000000000000
ME
03 00 0A 42 C2 41 22 FB 0B A4 40 80 B1 0C 07 28 10 0A 000000000000000000000000
Differences in bold... will have to pop out in a bit and go and do a screenshot difference ;)
« Last Edit: 13 January 2014, 18:13 by noobmonkey »
VW Golf MK7 GTD Manual 5DR Pure White
Offline noobmonkey
« Reply #114 on: 13 January 2014, 18:20 »
Ahhh possible stumbling block...
Out in the car, and re-read.
KevinM
Me
Component: BCM MQBAB H  H14 0112
Different hardware completely!?
Offline noobmonkey
« Reply #115 on: 13 January 2014, 18:29 »
Just for info, breaking down the different parts (using my hardware) this is what i see:
01 - He has Kessy (I don't)
1E - He has an Automatic (I have a manual)
46 - He has heated Front Seats (i don't)
01 - He has a 3 door (no Powered Rear Windows) - I have 5 door, powered windows
24 - He has 3 door - i have 5 door
1C - He has heated front washer Jets (I don't)
18 - He has ESCL Electric Steering Lock Installed (i Don't) - no idea what that is?
So in short... the difference aint in 09 Electric peeps...... (But damn the cars options don't make this easy!) - also... the HW model might have further invisible options with my HW.... therefore... it could still be here, doubt it tho.
Thank you hugely for posting though.
« Last Edit: 13 January 2014, 18:31 by noobmonkey »
Offline noobmonkey
« Reply #116 on: 13 January 2014, 18:34 »
i'm doing a channel map / export as i type. Could someone mail me a link or email me their csv export (09 - adaptation).  I'ma gonna go back over what has already be done, but nothing wrong being thorough :)
(Pm me to swap details) - hopefully that'll avoid some spammeryness and bots :P
Offline jivemonkey
« Reply #117 on: 13 January 2014, 18:40 »
You'll be a while! Took over 15 minutes for me, with 1700 channels exported... :shocked:
Offline noobmonkey
« Reply #118 on: 13 January 2014, 18:41 »
been at it 8 minute oooh yeah ;)
Offline Mark V GTD
« Reply #119 on: 13 January 2014, 18:49 »
I still think its the door controllers at the heart of this - are you brave enough to copy and paste Kevins coding in to replace yours Noob?
