Author Topic: Anyone with a Post BW45 car got VCDS?  (Read 47627 times)
Offline jivemonkey
Re: Anyone with a Post BW45 car got VCDS?
« Reply #100 on: 12 January 2014, 17:01 »
I'm loving the cooperation and the working together attitude on here, what happens when he flicks it into reverse and the mirror explodes? Hehe.
What would really and is a definitive list of working code modifications on the VCDS thread so newbies can keep track :)
For info, I'm working on collating this on a dedicated site. It's a bit rough around the edges as I've not had too much time to work on the aesthetics, but the raw info is there for anyone interested.
http://golf7vcds.moonfruit.com
Feedback welcome!
Keep up the good work gents.
Golf VII GTD | 5dr DSG | Deep Pearl Black | Dynaudio | Winter Pack | High Beam Assist | "Advanced" Phone Prep
Offline jmc
« Reply #101 on: 12 January 2014, 17:40 »
VW Golf VII, GTD, manual, Night Blue, Rear view camera.
Offline Mark V GTD
« Reply #102 on: 12 January 2014, 19:28 »
How do you take these VCDS screen shots chaps?
Offline jmc
« Reply #103 on: 12 January 2014, 19:34 »
Alt+PrtSc
Offline noobmonkey
« Reply #105 on: 12 January 2014, 19:44 »
i use greenshot, as 1 click (prt screen), drag the area and a link is placed in your clipboard :) :) (Just google it, nice n easy) :)
bit more power then windows tools and jing.
VW Golf MK7 GTD Manual 5DR Pure White
Offline Mark V GTD
« Reply #106 on: 12 January 2014, 20:32 »
It was reported on another forum that someone posting on BRISKODA.NET has solved this mirror unfolding on unlock problems - they did not post a  link though....
Offline noobmonkey
« Reply #107 on: 12 January 2014, 22:07 »
 :shocked:
Ooooooooooo! That was an interesting post.... pushed me to their forums, and onto another page! ...
http://www.stemei.de/pages/coding/vw-golf-7.php
(List on left once loaded)
Quote
Disable or adjust the volume of the Körperschallaktuators
In the VW Golf 7 and verbautem Soundaktuator you have the option to reduce its volume accordingly, you should use a creak or humming in the center area of ​​the instrument cluster perceive, or to disable it altogether.
The following coding is used:
Select STG A9 (Körperschallaktuator)
STG adjustment -> function 10
Select a channel volume of the actuator for impact sound
Value corresponding to customize default value: 100% In adjustment to 0, the sound amplifier is completely disabled
tonnes of others in there too, none that we in this thread are trying to find... but interesting :)
Offline kevinm
« Reply #108 on: 13 January 2014, 12:06 »
This is my BW50 with mirror un-fold on unlock:
Address 42: Door Elect, Driver (J386)       Labels: None
   Part No SW: 5Q0 959 593 B    HW: 5Q0 959 593 B
   Component: TSG FS        020 0025
   Serial number: 24111306070150
   Coding: 003F1220D001040100001000
   Shop #: WSC 01357 011 00200
   ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 4084BB7DDB7EA31ED43-8015
No fault code found.
Address 52: Door Elect, Pass. (J387)       Labels: None
   Part No SW: 5Q0 959 592 B    HW: 5Q0 959 592 B
   Component: TSG BFS       020 0025
   Serial number: 18111306070985
   Coding: 003F1020DE01040100801000
   ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   VCID: 3F86B881A680DCE6AD9-806A
Current: His: 2020 M340i   Hers: 2019 GTD
Previous:
2014 GTI PP DSG
GTI ED30 DSG
Offline noobmonkey
« Reply #109 on: 13 January 2014, 12:13 »
Thank you kevin, at work at the moment, but will confirm this evening :) - thank you!
Are you able to provide the long code for cent elec too? (09) :)
