Author Topic: front wheel bearings  (Read 3271 times)
Offline Craigwilson
« on: 05 January 2014, 15:53 »
how much play should be in my front bearings with the 30mm drive shaft bolt slackend off
Offline gazareth
Re: front wheel bearings
« Reply #1 on: 05 January 2014, 15:58 »
you are not meant to check for play with the nut slack. and there should not be any play when its tight. they tend to start howling first before you can feel any play in them though.
Offline Craigwilson
« Reply #2 on: 05 January 2014, 16:04 »
there's quite a large amount of play in mine and they don't make a sound
Offline Craigwilson
« Reply #3 on: 05 January 2014, 16:05 »
so as long as there's no play with the nut tight I'm all good ?
Offline gazareth
« Reply #4 on: 05 January 2014, 16:20 »
yeah they should be sound. they need to be pretty darn tight them hub nuts.
Offline Craigwilson
« Reply #5 on: 05 January 2014, 16:21 »
275nm aka scaffolding on power bar
Offline gazareth
« Reply #6 on: 05 January 2014, 16:26 »
jeez not quite a scaffold pipe :shocked:. 2 foot long breaker bar should be fine and then recheck after a couple of miles just to be on the safe side.
Offline weazgti
« Reply #7 on: 05 January 2014, 20:25 »
 On mine 260nm is not enough.
Offline Craigwilson
« Reply #8 on: 05 January 2014, 23:56 »
I done it with a bat and it came loose and causeing my brake to squeal when steering
Offline Gambit
« Reply #9 on: 06 January 2014, 09:08 »
Ideally you do not reuse hub nuts. Though if you dont have a big enough torque wrench, call into your local truck or bus mechanic and ask them to torque it!
