Author Topic: Sell, Fix, or buy lots of oil?  (Read 9200 times)
Offline Waspy
« on: 04 January 2014, 21:48 »
So my beloved mk2 8v is burning a fair amount of oil. It has done 188,000, but more to the point is that I am using it everyday and covering a lot of miles with my job which I hadn't expected when I bought the car. In an ideal world I would have the car for pleasure and have a run around to clock the miles on. But right now I just can't afford to run two cars.
So, brings me to my question.
Do I get it fixed, which is going to be piston rings and seals. Well, that's my guess on an engine with that milage. I tried a compression test but the results were between 2 and 4 bar, so I guess I did it wrong. I dont know the cost of this, but I am confident I can't do it myself. Alternatively a recon engine would be nice, but it seems that would be ~£1000. Which I don't mind too much as I plan it to be a car for life.... Providing I can make it run that long. The real comparison between these is if piston rings and seals will give another 100k miles, do I really need a whole new engine?
With the above costs considered. I could sell mine, use the money I would have used to mend the current one and buy what should be almost a minter... But it may actually have issues (better the devil you know?)
Finally I can get mine tuned by someone who knows what they are doing and just keep throwing oil it in until I can afford another car (a few years realistically)...
Opinions? Also can't find how to do a pole on the mobile version, but I'll add one when I can.
Cheers guys
Offline Lewy
Re: Sell, Fix, or buy lots of oil?
« Reply #1 on: 04 January 2014, 21:50 »
Fix, or ABF it.....
Offline Waspy
« Reply #2 on: 04 January 2014, 22:02 »
Oh yeah, ABF was an option, but I can't get insurance on it, so that's out. One vote for fix...
Offline Craigwilson
« Reply #3 on: 04 January 2014, 22:32 »
I take it the body and chassis is solid?, worth keeping, id fix it
Offline Gambit
« Reply #4 on: 04 January 2014, 23:05 »
Stick a mk3 2.0 8v bottom end on it. Least hassle and cost. And insurance wont know anything about it as it still looks like a 1.8 8v in the engine bay
Offline Waspy
« Reply #5 on: 05 January 2014, 12:18 »
Bodywork is good. I love the car, so selling would only be if it made perfect financial sense.
Interesting thought about the bottom end. Of course it could throw up similar problems a few thousand miles down the line as it will probably have come from a high milage engine anyway, no?
Added a pole.
Offline Sgt_Lemon
  • 8v owners club
« Reply #6 on: 05 January 2014, 13:32 »
I'm voting for 2L bottom end
VW BUSH
« Reply #7 on: 05 January 2014, 14:01 »
I say kill a Mk3 to keep it going, use the 2.0l 8v gti as a doner if you cant afford an ABF.
You can pick up fairly low mile failed rot boxes for under £300, not just the engine you can use either.
Worst thing I ever did was not fix my last Mk2 and let it go :cry:
Offline Waspy
« Reply #8 on: 05 January 2014, 14:24 »
Wow, a few of you supporting the 2.0 bottom end. Thanks for the input guys. However, if I replace the bottom end and its just the valve seals ill still have the problem. So I guess the solution is to have the valve seals done and while im at it stick in a 2.0 bottom end for longevity...
Offline Sgt_Lemon
  • 8v owners club
« Reply #9 on: 05 January 2014, 15:32 »
You will have the current 8v head off anyway if you put a mk3 bottom end on. Easy enough to replace the valve stem oil seals then. You could even give your head a good clean and reseat your valves. If it was me doing it I would clean up the bottom end too when it's out the donor so the thing is all fresh and new when you put it in.
