Author Topic: Sell, Fix, or buy lots of oil?  (Read 9204 times)
Offline gazareth
Re: Sell, Fix, or buy lots of oil?
« Reply #10 on: 05 January 2014, 15:47 »
the valve seals can be done without removing the head so that's what I would go for first. 9 times out of ten that's the reason for oil burning anyway. bottom ends rarely give any trouble. oil sure aint going to get any cheaper.
Offline Craigwilson
« Reply #11 on: 05 January 2014, 15:52 »
Theres a 2.0 mk3 gti 8v in a Glasgow scrapyard if anyone's close and wants it.
Offline Gambit
« Reply #12 on: 05 January 2014, 16:07 »
You could pick up a 2.0 bottom end for as little as 50, throw a set of bearing and rings in it for another 100 if you really want. Then drive it for another 100k mile
Offline Waspy
« Reply #13 on: 05 January 2014, 16:43 »
Im not really at a stage where I would be confident changing bearing or rings tbh.
I could really do with knowing what my actual compression results are. Havnt a clue why it was chucking out such low readings...
Might give the valve seals a go and see if it improves. The bottom end could be fine at the end of the day, its just whether it will stay fine for the next few years.
Offline Gambit
« Reply #14 on: 05 January 2014, 17:13 »
Does it smoke under acceleration?
Compression test usually better with two people.
Take all plugs out
stick compression tester in plug 1
Crank over car for about ten secs WITH throttle wide open
record and move on two next cylinder
compare all 4 results.
Offline Waspy
« Reply #15 on: 05 January 2014, 23:01 »
Haven't been able to see if it smokes under acceleration. If it sits and idles it smokes. On rare occasions it won't smoke at all. But 90% of the time it smokes on idle, be it on startup or traffic. But like I say I haven't seen if it smokes on acceleration.
That's exactly how I did the test as well, had two of us and we did exactly what you said. Might be a faulty tester tbh.
Offline Gambit
« Reply #16 on: 05 January 2014, 23:21 »
If it smokes on idle, and startup etc then it would point to valvestem seals
as for compression, ideally you want 180psi odd which is a fair bit more than 4 bar so id get a new tester!
« Reply #17 on: 06 January 2014, 13:43 »
Stick a mk3 2.0 8v bottom end on it. Least hassle and cost. And insurance wont know anything about it as it still looks like a 1.8 8v in the engine bay
They should be told, non declared engine change is a major problem if they find out.
Offline Sgt_Lemon
  • 8v owners club
« Reply #18 on: 06 January 2014, 17:31 »
How would they ever find out?
Offline Gambit
« Reply #19 on: 06 January 2014, 19:44 »
Exactly itd need to be a pretty sharp eyed insurance person to spot a 2.0 bottom end
