Golf mk4
Wazzzer
may sound stupid, but wheres my dv
Topic: may sound stupid, but wheres my dv (Read 2862 times)
mcgee9t2
04 January 2014, 13:26 »
just went out to replace the dv that is on the car with a 007, however looks like the guy before me has done a few things to it...
the place where the dv is normally located is bunged up. along with another pipe. there is a small unit under my air intake but cannot tell what that is... any help appreciated...
mcgee9t2
Re: may sound stupid, but wheres my dv
04 January 2014, 13:29 »
said pipe that's bunged up... you can also see where I belive the original dv is located? which is bunged up...
Untitled
by
mcgee9t2
, on Flickr
said unit that I have no idea what it is if someone could explain?
Untitled
by
mcgee9t2
, on Flickr
also, when looking at the front of my engine bay to see if it had been relocated, found this. no idea what it is? is it to do with secondary air intake?
Untitled
by
mcgee9t2
, on Flickr
Last Edit: 04 January 2014, 13:37 by mcgee9t2
james2
No scammers please.
04 January 2014, 15:19 »
Maybe it has been moved to the front of the car on the intake pipe after the intercooler , the last picture is the aircon refill.
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
mcgee9t2
04 January 2014, 15:22 »
Looked from the inter cooler cold side outlet all the way to the throttle boddy.
Only thing that's there is a sensor...
james2
No scammers please.
04 January 2014, 15:37 »
Does the car make a dumping sound or a flutter sound
Wazzzer
Moderator
10k hero
Golf GTI 1.8T AGU
04 January 2014, 21:13 »
Do you have another bung in the metal charge pipe behind the engine above the turbo?
1999 1.8T: R-Tech remap - 225bhp/256lb/ft : K03s : THS FMIC : THS PCR pipe : 2.5" stainless exhaust : THS FR3 Engine mounts : G60/VR6 clutch : Calibra Yellow injectors : VR6 MAF : Devils Own WMI : Forge 007p : Carbonio CAI : Leon Cupra R Brembos : FK AK Street coilovers : Votex skirts : Anniversary front : click --->
http://www.golfgtiforum.co.uk/index.php?topic=92175
mcgee9t2
Reply #6 on:
04 January 2014, 21:29 »
yeah, theres defanitly a dumping/flutter sound so there is a dump valve somewhere, just no idea where hes relocated it too.
not sure wes, will have a look tomorrow.
Wazzzer
Moderator
10k hero
Golf GTI 1.8T AGU
Reply #7 on:
04 January 2014, 22:57 »
Get some more pics, get one of the throttle body to IC pipe and the pipes at the back of the engine, it might be down there somewhere lol
mcgee9t2
Reply #8 on:
05 January 2014, 02:35 »
will take my bumper off tomorrow and pic all the intercooler to tb pipes. defanitly not on there..that I could see
cant say for sure about back of engine, but couldn't see it
but does anyone have a clue what the second pic is? quite interuiged...
Wazzzer
Moderator
10k hero
Golf GTI 1.8T AGU
Reply #9 on:
05 January 2014, 10:59 »
Not sure, I don't have it on my AGU but then they added a few bits between mine and the ARZ
The bung behind the hockey puck is where the DV should sit then it should link to the charge pipe off the turbo which I've just realised would be different on yours as you have a FMIC. Chances are you don't have a DV at all as it needs to dump back into the TIP where it's bunged up no matter where it's positioned
Golf mk4
Wazzzer
