Author Topic: may sound stupid, but wheres my dv  (Read 2861 times)
Offline mcgee9t2
Re: may sound stupid, but wheres my dv
« Reply #10 on: 05 January 2014, 11:25 »
didn't even know you could completely do away with a dv?
whats the reprocushions of not having one? will it do any damage, and what will I need to fit one again...
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #11 on: 05 January 2014, 12:05 »
You can but apparently it's not advisable on the K03 hence one being fitted from the factory. You'd probably have to have a take off welded on the turbo outlet pipe somewhere that would allow you to run a pipe back to the DV when it's fitted to the TIP again. I'll see if Google throws up an image of what I mean...
Offline james2
  • No scammers please.
« Reply #12 on: 05 January 2014, 14:59 »
yeah, theres defanitly a dumping/flutter sound so there is a dump valve somewhere, just no idea where hes relocated it too.
not sure wes, will have a look tomorrow.
If its a flutter sound the dv is stuck shut or it does not have one.
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline mcgee9t2
« Reply #13 on: 05 January 2014, 22:53 »
Yeah I can see al the pipes which I believe are the pipes which the Dv was connected too. Just didn't want to try put it on yesterday and somehow have another FB plumbed in somewhere. Which is why I didn't fit yesterday. Next weekend / during week I will get a pic of how I believe it should be plumbed in and see what you guys say.
