Author Topic: Bhp calculation  (Read 1258 times)
Offline Screech16v
  • MK3 20vt AGU
Bhp calculation
« on: 03 January 2014, 19:50 »
Got myself vag com so this afternoon i did a few logs,two 3rd gear pulls and a 4th gear aswell ,seen that a rough bhp figure can be had from the maf mg/s reading by dividing it by 0.8,how accurate or inaccurate compared to a dyno  is this from peoples experience,I was told by a vw mastertech that if the maf is reading correctly which it is, that it can be as close as 5bhp correct  mine was 169 mg/s so came out at 211bhp but I only got a remapped ko3 with the supporting and most people say ko3 is maxxed out at 200.Not forgetting the outside air temp was low.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Bhp calculation
« Reply #1 on: 03 January 2014, 21:45 »
it's a bit of a guess really, I've had readings that are 15bhp over and others that are bang on the money. A K03 won't hit any more than around 200bhp so you can rightly assume your calculation is slightly out
Offline Screech16v
  • MK3 20vt AGU
Re: Bhp calculation
« Reply #2 on: 03 January 2014, 22:09 »
Thanks wazzer I was just wishful thinking  :grin:
Offline Chris.
Re: Bhp calculation
« Reply #3 on: 05 January 2014, 00:05 »
Also the maf calculation doesnt take into account ignition timing.
Usually fairly accurate tho
Click For Build Thread
