Author Topic: Leak  (Read 2252 times)
Offline apie2004
Leak
« on: 02 January 2014, 13:04 »
Hello,
My car has started cutting out, car turns over and runs for a couple of seconds and dies. Today I went to check the fuel pump fuse and got a shock, then a load of water dripped out of the fuse box. My scuttle tray panel is pretty tatty looking and I am assuming that the water is coming in through this (and the blower motor on the passenger side) Where can I get a replacement? I had a look on Vwheritage but they only had the seal. There isnt a breakers near me so I am unlikely to source one locally. Are they still available from VW?
James
Offline oakgreener
Re: Leak
« Reply #1 on: 02 January 2014, 13:49 »
    Try the dealers, but probably not stocked. This is will be you only option. The cost hurts, but at least it's the harder version
http://www.ebay.co.uk/itm/mk2-golf-rallye-jetta-lhd-hard-scuttle-cover-/111247881147?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item19e6e3f3bb
Offline Sgt_Lemon
  • 8v owners club
Re: Leak
« Reply #2 on: 02 January 2014, 13:50 »
Have you checked ebay for any cars being broken. Even this site has a section for selling parts including complete cars being broken. The stealers should be a last resort.
Offline Gambit
Re: Leak
« Reply #3 on: 02 January 2014, 13:56 »
& make sure you clear out the drainage holes at either side of the scuttle
Offline jezza16v
Re: Leak
« Reply #4 on: 02 January 2014, 15:22 »
If its leaking on to the fuse box then its likely that the scuttle drains are blocked with leaves or other crud and the water is backing up to the bonnet release grommet and ecu mountings, these are ususally perished by now, then the water drips down and on to the fuse box. Replacing the plastic scuttle trays will not solve the problem if the scuttle drain holes are blocked as the trays dump the water off into the ends of the scuttle anyway.
Offline apie2004
Re: Leak
« Reply #5 on: 03 January 2014, 12:29 »
The pathways that the water runs through to the drain where blocked. I've cleared these out and a load of water came out of the drain.
Unfortunately I've ran out of electricity so have to wait until this evening to see if it'll start. Thanks again for your help!
