Author Topic: 9 fault codes  (Read 5055 times)
Offline davidgtrr34
9 fault codes
« on: 30 December 2013, 14:10 »
I have no power and im getting a very loud knocking noise from the top of the engine.
I fitted new spark plugs, ignition coils and a new wiring loom for the ignition coils
can anyone help
9 Faults Found:
17763 - Cylinder 1 Ignition Circuit
            P1355 - 35-10 - Open Circuit - Intermittent
17766 - Cylinder 2 Ignition Circuit
            P1358 - 35-10 - Open Circuit - Intermittent
17769 - Cylinder 3 Ignition Circuit
            P1361 - 35-10 - Open Circuit - Intermittent
17772 - Cylinder 4 Ignition Circuit
            P1364 - 35-10 - Open Circuit - Intermittent
17645 - Fuel Injector for Cylinder 1 (N30)
            P1237 - 35-10 - Open Circuit - Intermittent
17648 - Fuel Injector for Cylinder 4 (N33)
            P1240 - 35-10 - Open Circuit - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
            P0300 - 35-00 -
16685 - Cylinder 1
            P0301 - 35-00 - Misfire Detected
16688 - Cylinder 4
            P0304 - 35-00 - Misfire Detected
Readiness: 0110 1101
2004 auq, 550cc injectors, gt3071r, adjustable fpr, ebc, fmic, sachs stage 2, walbro 255, 3" turbo back, 3" custom intake, n75 n249 sai delete.
http://s103.photobucket.com/user/davidgtrr34/media/Mobile%20Uploads/20140531_192129_zpsgud6vsfb.jpg.html
Offline joshstanvw
Re: 9 fault codes
« Reply #1 on: 30 December 2013, 14:48 »
What's the engine code buddy is it an agu?
GTI is not a trim level. It is a lifestyle.
1999 1.8t AGU, KO3s, forge 007p, silicone tip and charge pipe, oil catch can, SS turbo back system, pipercross CAI, g60/vr6 clutch, 40mm apex springs, drilled and grooved discs, stage 2 remap.
Offline davidgtrr34
Re: 9 fault codes
« Reply #2 on: 30 December 2013, 14:54 »
its an auq
Offline dom
  • Back in a Mk4
Re: 9 fault codes
« Reply #3 on: 30 December 2013, 15:10 »
Did you clear any existing codes before you scanned?
Offline davidgtrr34
Re: 9 fault codes
« Reply #4 on: 30 December 2013, 15:18 »
ya I had 4 codes before (cylinder 1,2,3,4 open circuit) so I replaced the ignition coil loom and then a day later I got the knocking noise
Offline pickles
  • Next!!!
Re: 9 fault codes
« Reply #5 on: 02 January 2014, 12:38 »
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
Offline davidgtrr34
Re: 9 fault codes
« Reply #6 on: 19 January 2014, 17:00 »
I thought I would bump because I still have this problem and cant figure it out has anyone any ideas. I have started thinking it might be the ecu or the ecu relay
Offline pickles
  • Next!!!
Re: 9 fault codes
« Reply #7 on: 22 January 2014, 18:38 »
did you try your ignition amp or coil packs ?
Mapped
Nearly S3 time  :)
Offline davidgtrr34
Re: 9 fault codes
« Reply #8 on: 22 January 2014, 19:46 »
there is no ignition amp in mine and I sent it in for recall and got 4 new coil packs but it did nothing
Offline pickles
  • Next!!!
Re: 9 fault codes
« Reply #9 on: 24 January 2014, 16:27 »
have you still got your old coil packs or can get a hold of some. try swapping the coils out again for your old ones or 4 known good ones ie from another car.
check your earths as well and make sure your ground is going from the coil pack harness to a direct ground under the battery tray.
http://forums.vwvortex.com/showthread.php?3639849-Suggestions-MKIV-Jetta-Wagon-2slo-Ignition-Circuit-Open-Circuit-Problem
Mapped
Nearly S3 time  :)
