Author Topic: 9 fault codes  (Read 5054 times)
Offline davidgtrr34
Re: 9 fault codes
« Reply #10 on: 24 January 2014, 23:36 »
have you still got your old coil packs or can get a hold of some. try swapping the coils out again for your old ones or 4 known good ones ie from another car.
check your earths as well and make sure your ground is going from the coil pack harness to a direct ground under the battery tray.
http://forums.vwvortex.com/showthread.php?3639849-Suggestions-MKIV-Jetta-Wagon-2slo-Ignition-Circuit-Open-Circuit-Problem
I still have the old coils, I will try them tomorrow.
not sure about the ground because I have already completely removed the the loom for coils,injectors and all the sensors and found no problems. should I connect the earth for the coils to the battery earth
2004 auq, 550cc injectors, gt3071r, adjustable fpr, ebc, fmic, sachs stage 2, walbro 255, 3" turbo back, 3" custom intake, n75 n249 sai delete.
http://s103.photobucket.com/user/davidgtrr34/media/Mobile%20Uploads/20140531_192129_zpsgud6vsfb.jpg.html
