Author Topic: turbo  (Read 1069 times)
Offline markgti1.8t
turbo
« on: 28 December 2013, 00:28 »
hi there would a turbo have minimal side to side play in it if there's on oil thanks
AGU fk coilovers Powerflex top mounts full 3inch decat turbo back viper induction kit fmic vr6 clutch g60 flywheel catch can 007 forge dv Power flex wishbone bushes  Power flex dog mount under brace JOM  ADJUSTABLE Drop Links Walbro 255lph INLINE Fuel Pump wmi now fitted WAITING TO FIT VR6 MAF SAAB RED TOP INJECTORS STILL TO BUY K300 TURBO  CON RODS LSD
Offline harkerg
Re: turbo
« Reply #1 on: 28 December 2013, 00:35 »
Minimal side to side play is normal when not pressurised this is taken up by oil pressure
Offline gazareth
Re: turbo
« Reply #2 on: 28 December 2013, 13:11 »
as long as the guts of the turbo don't catch on the outer casing it should be fine to use. of course the more play you have in it the less mileage you have left before renew/rebuild time comes along.
Offline mar_k
Re: turbo
« Reply #3 on: 28 December 2013, 18:32 »
Even new/refurbished turbos have play in the shaft which as stated is taken up by the oil, side to side is acceptable but in and out isnt
